I'll offer an alternative opinion.  Save your money.  Take down the windvane, remove the wiring and put a Windex up there.  It's more sensitive to wind changes.  For years I wanted wind instruments and then when I got them I realized they were over rated.  For one thing the True Wind function depends on the accuracy of the speedometer - a very dubious proposition.  If you're paddle wheel is at all fouled you don't have accurate boat speed reading.  Even if it's squeaky clean you need to calibrate it using several methods which are in themselves subject to inaccuracy.  Want to go faster?  Just go into the menus of your speedo and turn up your speed!  Your display speed through the water is arbitrary.
Also the wind direction is slightly behind what is happening.  So if you go solely by that you will be late reacting to changes in wind speed and direction - if that is important to you.  A windex is never late.
What would be an improvement is a video camera at or near the masthead with a display in the cockpit so that you don't have to crane your neck looking at the windex.  Tell Tails on the shrouds and sails are cheap and reliable (Although video on the jib's would be nice to have in the cockpit where they are often not visible  to the driver.
Ok, I don't understand a word of this argument!
  First of all, there is nothing more useless than a wind vane that you never look at because it gives you a pain in the neck!  I buy the argument that tell tails give the most immediate response and I agree that you basically don't need any gadgetry to enjoy sailing, or even to get the best performance out of your sailing via more traditional means.
But you don't need to rely on your paddlewheel for speed accuracy.  I set mine to SOG from GPS.  I think I've heard it said that's not right … true wind speed and direction
must be derived from the boat speed thru water based on the paddlewheel. I must be missing something because that just makes no sense to me. True wind and direction is based on your speed on earth as far as I can tell. If your boat speed says you are doing 7 knots but your GPS is telling you that SOG is 6 knots because you are bucking a current. How is telling the instrument that you are going faster than you actually are going more accurate?
  I need that explained.
And why is the wind direction from the transducer slightly later than the windex?  I don't buy it.  First of all, you can't prove it by trying to look at both simultaneously.  You'll break your neck trying!  If there is a difference, it has to be trivial.  Maybe I'm jaded … I haven't had a windex on a boat that I've sailed in probably 40 years, and I've never missed it.  Not having the wind instrument, OTOH … can't say that I would go very far without one.
