I think they look really nice as is...I installed my curtain set up this weekend. I came out alright, however I think I might ad another panel to tighten up the pleats.
I think they look great. I believe that you made them the correct height because they are tiget at each end. Are they mounted on rods? If so, it is likely that the tension in the fabric is causing the rods to bow inward so that the center appears to be loose. If you make them shorter, it will increase this tension in the fabric that will create greater bowing in the rods.I installed my curtain set up this weekend. I came out alright, however I think I might ad another panel to tighten up the pleats.
How much $ for that mod?switching to a servo motor is a dramatic upgrade
If your machine takes the same motor as the Sailrite Ultrafeed machines, you can get almost the same performance as a servo motor with the Worker-B for under $400. Sailrite® WorkerB® Power Pack Motor System (110V) - SailriteHow much $ for that mod?
That was originally a Singer 111W. Other companies (Consew, Tacsew, Sailrite, etc) cloned it.Does anyone here have a Sailrite Fabricator? I hear the predecessor to that one is the Tacsew T111-155. I'm looking at one for sale now. It's a straight stitch, walking foot, industrial machine.
