The Sewing Machine Thread
Ward H
Nov 7, 2011
3,807
For Sunbrella and similar materials I use a #20 needle when using v92 thread. I use mostly Schmetz sharp/round point needles.
I also use DST basting tape which helps to seal needle holes.
Apr 5, 2009
3,195
We got tired of restiching all our outdoor sunbrella projects at least two times before the fabric needed to be replaced. We switched to Tenara thread for all outdoor projects and have never gone back. The thread is clear so it color matches whatever you sew with it. With LS1 or LSZ1 oscillating hook bobbin, it would have been better to get the Sailrite HDPE Lifetime thread, but it was not available when we got our Tenara.
It took some fiddling, but I was able to get our LSZ1 to sew perfectly with Tenara.
Apr 5, 2009
3,195
I installed my curtain set up this weekend. I came out alright, however I think I might ad another panel to tighten up the pleats.
I think they look great. I believe that you made them the correct height because they are tiget at each end. Are they mounted on rods? If so, it is likely that the tension in the fabric is causing the rods to bow inward so that the center appears to be loose. If you make them shorter, it will increase this tension in the fabric that will create greater bowing in the rods.
You might see some improvement by coming up with a way to support the rods at each dividing point in the curtains so that the unsupported length of the rods is shorter.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Resurrecting this thread...
I'm jealous of you Sailrite owners. I finally got my Alphasew working O.K.; it took about $50 worth of parts from Sailrite! :)
I'm going to change out the crappy foot pedal, too, with an old reliable Singer rheostat pedal. The Alphasew electronic one works, but the mechanical part is so crappy it's almost impossible to use well.
