How does one do that?I think you need to make the marina responsible for this job.
dj
dj
If you do it yourself you are responsible.How does one do that?
Make sure all work is done with paperwork.How does one do that?
I will try to get him to sign a 6 month guarantee on the work.If you do it yourself you are responsible.
If the marina does it and things later go south, they could be held responsible.
I’ll definitely keep that in mind. This guy didn’t even check my thru-hulls—he just said, “they’ll last longer than we will,” and painted right over them without inspecting anything. I get the feeling he just wants to get paid and move on.Whether now or later, consider the Marelon OEM Series 93 thru hull with valve, which includes the thru hull. It has a built in flange (3" I believe. They call it a king nut) They are used by many boat builders.
They are easy to install, come with mushroom head thru hulls or flush thru hulls. I put mine on 3 1/2" G10 1/8" thick backing plates for extra strength and to have a smooth surface for the king nut. Backing plates are easy to cut out of a sheet of G10 using a hole saw. Then drill the correct size hole for the thru hull in the backing plate and epoxy it into place.
A lot of traditionalist want bronze but there are a lot of boats, used and new with Marelon. I haven't heard anything bad about the Marelon OEM Series 93 thru hull.
As I also have a 30' boat, I'll mention that all of my thru hulls, sink drains and water intakes are 3/4".
In the first picture it looks like the bottom was painted while the boat was in slings, and the area under the slings not touched up. No big deal; you might just want to make sure to sand that section a little extra before repainting the bottom when you do.Paint looks good. Just wondering about the two pictures here. What is the purpose of painting the rudder? Just curious about the process.
Good luck with that. Be careful about taking an adversarial approach.I will try to get him to sign a 6 month guarantee on the work.
Okay, that's a great idea. I'll just ask for it through text casually. I just hope it goes smoothly.Good luck with that. Be careful about taking an adversarial approach.
A softer approach would be ask if he guarantees his work, and if so ask for his guaranty in writing, or just ask for this in an email or text and his reply in writing is sufficient. You need to work with people who provide services, not against them. Keep it friendly and agreeable whenever possible. If you seem like a troublemaker they will avoid you and will be “too busy” or they’ll give you their worst (“I don’t want your business”) price.
Something was lost in the translation.My boat is finally out of his yard and I'm trying to get it to a DIY yard to employ the wonderful advice from this thread.
Here is some of the work.
There are so many violations of 'best practice' and of 'common sense' in those photos, that one's mind boggles...Here is some of the work.
These photos reinforce my philosophy of learning about boat systems & repairing by “doing it yourself” when possible. I learned quite early after one particular boat yard messed up several repairs and I had to go back & fix properly. Costly mistakes on my part until I wised up! You received sound advice from several experienced members on how to accomplish replacement of the defective ball valves. No one suggested the repair as seen in the photos! I know that the yard was pressuring you; however, you could have purchased replacement valves, tailpieces, & hose and swapped them out in three hours or less without the yard being aware. (Without replacing the thru hull fitting) and requesting that the yard splash the boat. Then do a more thorough repair (replace thru hull fittings) in a few months on future scheduled haul out.My boat is finally out of his yard
I think the prior 4 four posts are ignoring the above part of the OP's post #111.... I'm trying to get it to a DIY yard to employ the wonderful advice from this thread.
Again, not to be unkind, but the OP thought that these were OK repairs, I would be worried about their skills or knowledge to do one’s own repairs.I think the prior 4 four posts are ignoring the above part of the OP's post #111.
He is working toward a good solution. he has replaced the defective ball valves which, I think, were his original problem. In doing so he has used Groco flanged adaptors which solve the mismatch between straight and tapered threads. He has said in prior posts that he is working on better backing plates and I assume he will follow through on what he has said and will use those backing plates to properly install the flanged adaptors. Personally I think what has been done is a good interim step and better than what he had. You can't second guess him on whether he had the time or ability to do a more complete job in the time the yard he was in would allow.
The hose and through hull without a backing plate or valve is certainly an eye catcher but the through hull is the same as it was before, with what appears to be a new hose. An improvement. I think, (hope) that fitting is for an above the waterline head sink drain.
I assume @testingthewaters91will keep us aware of his progress
Not to be argumentative, but where did he say that?Again, not to be unkind, but the OP thought that there were OK repairs...
Greg
Well, he didn’t say “holy crap…look what the yard did!”Not to be argumentative, but where did he say that?
He said today in another post:
Today at 7:37 AM
"I’m going to haul out to a DIY yard soon to install proper seacocks and also tackle some remediation on the pedestal under the compression post."
