Well, it's been a long day but the boat is up and on stands.
Had to return the stands I bought as they were too big. Got the next size down and it was a lot more manageable.
Started by lowering the trailer nose as far down as it would go then placed the rear stands (and tied them together) and jacked up the front. Had to reposition the stands because it was causing some oil canning. So started all over with the stands in a different spot and it was all good until we got to certain point and noticed the rear stands were starting to tilt back from jacking up the front. Put blocks between the bunks and the boat and repositioned the rear stands again. Jacked up the front a bunch more and placed the stands in and tied them together. From there I just cranked the turnbuckles on the stands until I got to where it is. I'll probably go a bit higher in the front if I want to get the trailer out.
The 2x8 under the boat was what I planned to use to support the boat while I remove the front stands and roll the trailer out. I can't use it though, I would have to get the boat really high for the fenders to pass under. I might use 2 - 2x4s screwed together so it will fit easier. I might also remove the keel first to make the boat lighter.
The keel is very wobbly so I'm a little concerned what it's going to look like.
