Moving boat to new slip. Dockline Questions.
Gunni
Mar 16, 2010
5,937
Forward spring, aft spring always - keeps the boat on location, so your bow and stern lines just keep the boat lined up. Long, like Capta describes. What is a boundry line? In any case don't rig that Rube Goldberg bow line stuff your neighbors have, that is some seriously silly stuff. If you tie off to dock cleats make sure they are bolted with backing plates.
Likes: JamesG161
Beneteau 323 Annapolis MD
Gunni, the guy does what he has to do to make it work for him. His boat, his choice. You don't need to ridicule him just because it's not "Your way". Ease up - be nice.
The line that crosses the bow is a large U shape tied two both dolphins and running forward.
That 'U' configuration, you show, is mostly to put the dock lines within easy reach of the bowman when the boat comes in to tie up. There is some stretch added for tidal range, but there are simpler ways to do that. I like the idea of it. Because they are bow-in, the dockside bow lines are a long reach away. Less boathook work and no need for a dockboy.
My question is also, what are the conditions there? Tidal range, etc. I also recommend lots of bumpers, especially between you and your neighbor.
-Will (Dragonfly)
7,520
Alden 50 Sarasota, Florida
There is no right or wrong way to do this. There is only personal preference and what works for you. Try different configurations to determine what works best for your need.
As I mentioned earlier, we have similar docks at our marina and almost everyone configures their lines differently with effective results.
pateco
Aug 12, 2014
2,207
How much tide do you have there? If it's just a foot or two it's probably not worth the extra cost and chafe risk. If many feet then maybe?
-Will (Dragonfly)
What have you got for tidal shifts? Whats the difference between high and low tides? What do you get for winds? Currents? Are you fairly well sheltered?dj
This location is on a dead end canal off of the ICW.
The predominant average hourly wind direction in Pompano Beach is from the east throughout the year, averaging 9.8 mph in the fall and spring, and 7.4 mph in the summer.
What is the depth of your berth at low tide, for your keel clearance?
Jim...
According to the Slip's owner we have 8 feet at the slip
pateco
Aug 12, 2014
2,207
I have revised my thoughts trying to get it a little more to scale, and adding some bumpers and my dink to the drawing.
JamesG161
Feb 14, 2014
7,842
Hunter 430 Waveland, MS
I tie my boat to allow an slight oval shape movement, this assures me no sediment build up for my 5' draft.
We had a major North wind that drove the canal level down well beyond the low tide. People thought the boat was sitting on the bottom. I said no way. Why, because that oval shape movement basically "plows" a hole under my boat. My Zinc diver confirmed it.
My shot at your "bow in" view.
1) Finger pier side midships cleat "spring line". This the first docking line connected and last removed. This one line secures your boat and should be length set for tides only.
2) Your post #13 Port side spring line, set to prevent bow/dock collision :plus:
3) Both of your brown stern lines set for tide changes will stabilize your boat Port/Starboard swings.
4) You don't need Red or Blue lines at all.
Last comment is that a 3 foot tide change may cause the port side neighbor a problem if his boat's beam is wide.
Jim...
JamesG161
Feb 14, 2014
7,842
I would add the dinghy [post #28] at the end of the finger pier using the three bollards to tie it up, independently.
Jim...
Likes: pateco
Gunni
Mar 16, 2010
5,937
I have watched three different boats careen out of control in the slipway and strike other boats which extend beyond their slip pilings. The further out, the more often they get struck.
That should be good. It'll help the boat stay close to the finger pier so getting on and off will be easier. Also if you have a right hand prop it will counteract prop walk in reverse.
2 considerations about putting the dinghy in front of the slip - It will push the boat back possibly bringing the widest part of the boat behind the finger pier, making boarding a bigger step; and if it makes your boat stick too far out of the slip your neighbors might not like that (plus having the stern stick into the fairway makes it a target for others docking).
pateco
Aug 12, 2014
2,207
Jim...
1) Finger pier side midships cleat "spring line". This the first docking line connected and last removed. This one line secures your boat and should be length set for tides only. (I Currently have no Midships cleats at all)
2) Your post #13 Port side spring line, set to prevent bow/dock collision (I was planning on adding at least one Midships Cleat) I found just one almost matching one in a boat part consignment store last year.
3) Both of your brown stern lines set for tide changes will stabilize your boat Port/Starboard swings. (Agreed)
4) You don't need Red or Blue lines at all. (If I forgo the boundary lines RED, I think I still need Bow Lines BLUE)
JamesG161
Feb 14, 2014
7,842
A Big OUCH!
I wonder how you do a quick single side docking for fuel or eats?
My midships cleat is almost a necessity. We do single line berthing with that cleat, but ours are OEM.
Someone used our "boarding line" that is extra line[at midships] to pull the boat to the finger pier. That extra line was left tied up to a Bollard cleat. Tide went out... Guess which cleat gave up?
errr... not the Hunter OEM cleat.
So the backing plates are designed for the weight of your boat on a new cleat.
_____
Without midships spring lines....
1) Brown sterns for sure
2) Blue Bow lines for sure, but I don't think a "spreader" is needed.
3) To board, release Port side Blue and pull with Starboard Side Blue to finger pier
4) To dock, throw Bow Blue to landlubber or kiss dock and grab the Starboard side Blue. Set the Browns, exit boat, set the Blues.
____
The real "kicker" is a bit of Trigonometry, since I don't see the Actual Scale of your boat and the width and length of your berth. That Trig is the High and Low tides and the angle of the Brown and Blues.
For example: At Mid Tides, your boat may hit the finger pier or the neighbors boat, with the slack in the lines.
Jim...
PS: I had to do Trig for Hurricane Nate's expected 10' surge and allow enough line for my boat to rise, without hitting the Bulk heads on either side of the Canal, after the surge passed.
pateco
Aug 12, 2014
2,207
For example: At Mid Tides, will your boat hit the finger pier or the neighbors boat, with the line slack.
Jim....
That is the reason for the red lines. they are not tied to the boat but instead to the pilings, and (via the blue bow lines) the seawall cleats. They act to coral the boat at mid tides keeping it in the center of the slip. The below pic is of a friend's boat at a similar slip at low tide. He has let the boat drift over to the pier for boarding by loosening the port bow line.
I need to take another pic with it at its centered position, and one at mid tide. I will also take some more exact measurements the next time I am there.
JamesG161
Feb 14, 2014
7,842
They[Reds] act to coral the boat at mid tides
Not too bad of an idea, if they are independent, non stretching 3/4 inch lines that are fixed in an Fence type especially on the Port side. In other words, straight and not part of boat lines.
But it may take 2 lines on each side and have anti chaffing on the lines. Think of a boxing ring type ropes.
then Fenders on the port side, since the finger pier is your block.
____
If you get the Bollard to Bollard [berth Width], Port Bollard to Dock, Stbd Bollard to Finger, , length of finger pier, and Finger pier height above water [known tide at the time], measurements, we can do the Trig in a PM if you need help.
But it looks like you won't need the Reds, at first guess.:pimp:
Jim...
dLj
Mar 23, 2017
4,520
Not much tidal change, pretty secure location, not sure about he currents, but sure looks to me like the perfect location to try hanging weights on your springs. Not having center cleats is something I'd address as soon as I could, but heck, it's your boat.
In your diagram, I'd add a second spring on the other side too. With two springs and weights on both, your boat may just sit there very nicely... Takes a bit to get it all adjusted just right but once you do, it's pretty neat how it keeps your boat from moving around... Good luck with the move and take photos once you are set up. It will be interesting to see how you finally get settled.
dj
pateco
Aug 12, 2014
2,207
dj
What would you use as weights?
dLj
Mar 23, 2017
4,520
I used square cobblestones. They were easy to make a rope cradle for and had good density and water resistant.
dj
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
google “Johnson toe rail folding cleat” for mid center cleat. Have em on my H31
