Moving boat to new slip. Dockline Questions.
pateco
Aug 12, 2014
2,207
After three years at my current dock, I am moving my boat to a new slip. Currently I am side docking to a dock behind a residence.
The Stargazer is the sailboat on the left with the blue bimini. I have two mooring whips, bow, stern, and two spring lines.
My new dock is a a slip with two dolphins and a half pier. With two cleats on the seawall.
My boat is going where the one with the blue canvas is above. below are a couple of pics of it empty.
I have drawn up a rough diagram of the slip with a sailboat in it.
I am trying to figure out the best way to tie her in this new slip, and am looking for suggestions.
Below are examples of how two of the sailboats belonging to fellow sailing club members have configured their bow lines in this same location.
The line that crosses the bow is a large U shape tied two both dolphins and running forward. it is supported by the two bow lines that are tied to the cleats on the seawall I am considering something similar, but looking for suggestions. When the boat was originally in Baltimore, the PO had a similar configuration except he had a large bumper attached to the line that crosses the bow.
These are the only two sailboats tied this way at this location. Most of the rest have bow line from seawall cleats, stern lines from the dolphins, and one spring line from the dolphin in between the two half piers. Below is a google earth screen capture of a couple of the other sailboats at this location
Fire away with your suggestions.:biggrin:
Likes: zeehag
JRT
Feb 14, 2017
2,057
Won't boarding be a pain bow in first? All the sailboats in finger piers at our marina are backed in by the stern.
pateco
Aug 12, 2014
2,207
There are a couple of sailboats stern in, but not many. The issue is that this is not a standard marina, but half pier slips coming off of a concrete sea wall. The water depth near the wall is substantially shallower than it is a few feet off of the wall. Bottoming the rudder is a major concern. From my observations, boarding a sailboat at the side from near the end of the half pier will not be difficult. Some of the boats do have small plastic step stools for high tide conditions. You can see from this photo that the starboard side of the bow comes very close to the end of the pier.
7,424
Alden 50 Sarasota, Florida
The view is always better when you go bow in. Not so much the sidewalk gawkers but on a bulkhead like that, most of the folks at our marina go bow in. I've wandered around a bit and the only thing evident is that everyone ties up with spring lines to the pilings to ensure the boat won't move forward.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
We kept or boat (2000 H340) in an almost identical slip for many years, although our finger pier was on the port side of the boat when bow in. We went bow in because of the water depth near the end of the slip and the ease in docking the boat. We did not use any of the complex bridle slings to keep the boat centered and the bow off the dock. Basically we had one bow line on each side (uncrossed). We used aft spring lines on each side, one secured to the bow cleats and one to the mid-boat cleat. We did not need any forward spring lines because the bow lines kept the boat from moving backward and out of the slip. We had one uncrossed stern line tied from pilings to the stern cleats on each side.
Regarding getting on and off the boat: we had a gate cut into the life-lines on the side facing the finger pier. We just had the lines cut and pelican hooks installed (see photo). We also used a wooden step to board the boat when the tide was at flood.
You may need an additional slip-long line and fender to keep your boat neighbor off your boat.
Where I grew up in New Jersey virtually all sailboats went in bow first to those types of slips. Here in Maryland everyone is stern-in (except us). The view certainly is better and it's still manageable to get the boat close enough to the finger peir to get off.
In terms of how to tie up in that kind of slip - the U shaped bridle you took pictures of looks easy do dock single handed, but it also looks like a lot of chafe points so I wouldn't rely on it. I'd just put a line from the bow cleat to each dock cleat, one from each piling to each stern cleat, and a spring from an aft piling to a midship cleat. For the port bow line you'll probably want two marked lengths - one when you're at the boat and want to be close to the pier, and one when you're away and want to ensure the boat can't rub.
Likes: pateco
Oct 30, 2017
196
Caliber 40 LRC Lake Pueblo
not to hijack the thread but I do find this interesting.
At our marina most of the sailboats in bow first are the ones that are there for the "marina atmosphere" and rarely actually are seen out on the water.
we dock stern first because it gives us a better view while sitting in the cockpit.
pateco
Aug 12, 2014
2,207
That is interesting, as the ones stern first here are those that don't look like they have moved in years, and the bow first ones are those I see sailing every weekend. Different location, different preferences.
Likes: LloydB
Jul 7, 2004
8,485
Hunter 30T Cheney, KS
I would have expected just the opposite as I see "marina atmosphere" as sitting closer to the gangway and greeting passerby's. Bow first says to me "we want our privacy".
That dock arrangement would drive me crazy. We have fingers on each side. But then, this is Kansas, not one of those highly crowded marina spots.
pateco
Aug 12, 2014
2,207
I agree it is not what I would prefer, but the rent is good for the area, I will have 8 feet of water, (no more getting stuck at the dock), and it saves me almost 2 hours on the ICW every time I sail since it eliminates four bridge openings, two going out, and two coming back.
capta
Jun 4, 2009
4,926
I like the longest spring lines I can manage, fore and aft on both sides, if possible. I'll pull them tight against each other at mid-tide, or in a lot of tide a bit of slack. This will keep her pretty much in the same place in the slip at all tides. Then throw on a couple of bow and stern lines and adjust them over a complete tide cycle as best I can. If I'm coming and going a lot, I might have a second shorter spring, bow and stern lines to make docking easier, then change to the permanent set. I always use independent lines in case one breaks, so it doesn't affect any other line. Chafe gear is your best friend.
Once you get her all snugged up and familiar with your dock, on a calm day you can turn her around and use your prop to blow out the mud and much build up along the seawall. It helps a lot if there is a good current.
I'd do it quietly, as many areas consider moving mud or muck from one location to another this way to be environmentally damaging. Go figure?
196
Oops. yeah I had it backwards. I posted that while trying to listen to someone complain at work and just got bow and stern swapped.
This is what I am thinking so far.
I'd probably do away with the starboard boundary line. It'll be hard to get that one tight enough to do any good, and it might become a trip hazard getting on and off the pier. Personally I'd run the port boundary line straight from the piling to the port dock cleat, but maybe experiment with both and see what works. Also if your boat is really so long that it sticks out past the back pilings then I'd go with two aft springs rather than one, since the aft lines won't do any good keeping the boat back.
May 1, 2011
4,997
Pearson 37 Lusby MD
Chip, recommend you also consider a forward spring line. I solo most of the time and go for my spring lines first when coming back to the dock. All my dock lines have a bit of white tape as markers for where to do the cleat hitch. And I'm a stern-first guy because it's easier to get on/off the boat.
JamesG161
Feb 14, 2014
7,766
Hunter 430 Waveland, MS
I always berth, stern first for power and shore water connections.
What is the depth of your berth at low tide, for your keel clearance?
Jim...
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Tide Minders
I added one set recently and love it as I keep it real tight and works real good keeping the boat from moving forward or backward and the fender stays right up against the pole and I use it on midship cleat to pole.
A few months back during Irma pulled all the water out of the canal and my boat was leaning over real bad.
It rolls up and down the pole real good and my dock is shorter than my boat and this one pole is the only pole I can tie real tight.
Nick
dLj
Mar 23, 2017
4,398
What have you got for tidal shifts? Whats the difference between high and low tides? What do you get for winds? Currents? Are you fairly well sheltered?
One of the things I've done is on the rear spring lines, take a heavy weight and hang it off the spring line via a small rope with loop running down the spring. You take the weight, make a loop that runs down the spring line, then you can run a small line and hold the weight at one location. That constantly holds the boat at one spot. When you get on or off, you can simply pull a line on the side you board and bring the boat to the half dock. Just a thought, doesn't always work, depends upon currents, tides and prevailing winds...
dj
