Tomorrow's the big day for raising the deck and applying adhesive. While that is drying ill start on the rudder mount.
I rubbed a sharpie all over the area then sanded until just the cracks were left. can see the Marinetex hole patches i made. Looks like the cracks may have been repaired by a previous owner and they came back. My repair was still holding tight, but the cracks spreading on top were making me nervous.
What's interesting is the marinetex repair shares the same crack as the luran. Rudder mount repairs are common and there's already some good threads on that so i wont bore anyone, but note that this crack looks the same as the picture of the OP's boat.
That upper rudder gudgen is longer than the bottom so there is more twisting going on up top. I see if i can order so high density backing plates. I wonder if a good repair actually hastens cracks...
Revelation to me probably obvious to most..Hardware should never touch luran. The MarineTex allowed the rudder forces to transmit directly to the luran only. Must leave gap bigger than bolt, and fill gap with flexible sealer
