JD4;
Thank you for the photos. There is no question that resin was added into the bilge, still I could not see if there was any pulling of the bolts. You never advised what you paid or the exact estimate.
When the boat was built either in CA or FL plants but probably in the CA plant, the washers and nuts would be on top of the bilge floor not below the added resin. You now report no leaks.
Usually this will be your first and not last boat, so keep it and learn to work on it. Many folks will tell you to try and remove the keel yourself. That would be extremely risky with that heavy cast iron keel. As I said before, I owned American Marine &Sail Supply which was known to be a small boat sailboat dealership and the two biggest dealerships were Catalina and Hunter. Personally I have changed many keels over my lifetime and even put on wing keels removing the fin keels or swing keels. It is not an easy job and one not for those who think they know what to do. One slip and the keel could fall over and serius injury or death unless you have the experience tools and jig to hold that keel up in place which I did. On a trailer, that is nuts.
I am speaking from a professional standpoint. I am retired but Frank Butler whenever he was redesigning the smaller boats called to ask my thoughts which I understood I was the only one he called. Again it would be interesting what you spent on the boat and the cost of the entire repair which is debateable .
