Well, water continues to go down, the Oklahoma temperatures are brutal again this summer, but with the help of evaporative cooling, I got a little work done on the sailboat from 9:00 to midnight last night.
First off, if you have never checked out the Port-A-Cool brand of evaporative coolers you ought to. I have been around several different models, in high and low humidity, and somehow they just work all the time regardless of RH. Don't ask me how, I dont get that they work in higher humidity either but they work. I have the Cyclone 3000 and love it. I used it on LOW fan speed last night! I was quite comfortable in front of it despite the temp still hovering above 100 after dark inside the shop.
Started work on my standing rigging finally. I am using the Norseman swageless ends, in a kit from CD. the kit is for standard or tall rig, so you cut shrouds to final length yourself. Never had my backside puckered so tightly as when I finally got to the point of cutting the backstay to length!
I was really having a heck of a time trying to get a fair/flat means of laying the cables, (old and new) side-by-side to compare lengths, turnbuckle settings, (old) etc, so I could make an informed decision about where to cut the new cable. Staring at one of my drills I had an inspiration. My shop was originally built as a dozer repair shop... The floor is a monolithic pour of heavily reinforced 10" thick concrete. There are no cracks, (well, okay, one). It is so thick, I had no problem deciding to drill a hole to receive a stainless bolt.
I took the upper swaged fittings of both old and new shroud, tied them together and concentric through the stainless bolt and dropped the bolt in the hole. Voila, the upper ends of both shrouds are now mounted concentrically, and I can pull them taught side-by-side on the floor to determine a proper cut length. This will come in super handy as I can now use this repeatable method to carefully lay out the rest of the shrouds, and it will allow me to get uppers and lowers exactly the same length quickly and easily.
The old saying measure twice, cut once TOTALLY does not apply here. When cutting a $150.00 hunk of wire you measure way more than twice, especially when it is your very first attempt.... Try maybe 40 times?
After experimenting with a hacksaw, (I don't want to look like Popeye after this) and a metal chop saw, (if un-welding individual strands is your thing go for it, but I don't recommend it) I finally went out and bought the crafter's tool of choice; a Dremel. At low speed, with the big quick-change flexible metal blade the Dremel tool does a nice job of making a cool-temperature cut without welding the individual strands of wire together. It does it cleanly too.
Follow the Norseman instructions carefully, slowly, reading them 5-bazzillion times, and you know ALMOST enough to do the job. Here's the very valuable tip I got from Maine Sail (thanks!!!): use TEF-GEL anti-sieze paste on the threads of the compression fittings whild forming the wire's outer strands over the internal cone. This prevents galling and allows the two mating parts to easily screw together and back apart without damaging the threads. Clean the TEF-GEL off with a solvent prior to final assembly.
See pics below to show the work I did, over 3 hours, on a single termination.... I know the rest will go quicker, now that I have the first one done. Again, thanks to Maine Sail for the advice and guidance!
