I was told to then run the transmission for a bit, dump that new fluid you just put in and replace again with new.Upon opening the transmission, I could not see any water. I will be removing all of the ATF and replenishing with new.
dj
Very good question, Dave.Bilge pump?
That PSS Shaft Seal vent hose has always seemed to be an unnecessary vulnerability to me. The original PSS Shaft Seal design for sailboats did not include that hose. Instead, you were only required to burp the seal once when launching in the Spring. I have had that ventless design PSS Seal for over a decade without ever desiring to add the later design version vent hose. Hang in there, John.When it fell beneath the level of the Heat exchanger, a siphon event occurred and water flowed up from the PSS Shaft Seal through the Heat Exchanger and out the pipe dumping the water into the bilge.
The other two possibilities are:That PSS Shaft Seal vent hose has always seemed to be an unnecessary vulnerability to me. The original PSS Shaft Seal design for sailboats did not include that hose. Instead, you were only required to burp the seal once when launching in the Spring. I have had that ventless design PSS Seal for over a decade without ever desiring to add the later design version vent hose. Hang in there, John.
Yeah the bilge pump was located where you describe. It was an electric diaphragm pump. He moved his boat to Mathews Point Marina and I haven’t seen him since so I don’t have info on the exhaust.My primary bilge pump is located behind the engine bulk head on a shelf. Is that where your friend has it located?
What does the boats, exhaust hose and engine connection look like. I am needing to rethink the exhaust system.
And then she just went varooom. The water pump sent cooled exhaust out the stern. YEAH!
WHOO HOO!!!!Last evening I got to toast the success with @LeslieTroyer and @MikeHoncho here on the dock. All of my SBO friends felt like you were there.
CHEERS.![]()
WHOO HOO!I also shared my engine start good news with him![]()
Fantastic news John! Perseverance won out. I will raise a beer to you and your success.I can report, yesterday was a very good day!
We completed the assembly of the engine, enough to test a start.
She coughed. She sputtered. And then she just went varooom. The water pump sent cooled exhaust out the stern. YEAH!
She started without the need of chemicals sprayed in the air intake. We stopped the engine and then started again. We put her in gear at the dock. Transmission went smoothly into gear. The PSS Shaft Seal kept the water outside.
She is off the critical care unit and now we need to finish cleaning, rebuilding the electrical (we’ve accomplished about 75% of this task.
There is still some woodwork clean up from her testing her submersible skills. That did not go well so no further tests are needed.
With some home duties scheduled for September, I’ll be buttoning her up until October when a local sea trial can be run.
Winter sailing is looking likely in my future.
Thank you all who provided support, ideas and encouragement. You guys were wonderful.
CHEERS.![]()
