Captain tolley's creeping crack cure to the rescue!!!
This product really works!!!! The video is a hoot! Is this guy for real?
http://www.captaintolley.com/movie/movie.html
I noticed silicone sealant around ever port and fitting on the deck during my first inspection of the boat. I knew then I would be re-bedding ports, cleats and such plus possibly dealing with soggy core.
The silicone did absolutely nothing to stop the leaky ports. I removed most of the silicone and the leaks did not increase at all. Just a waist of material and an ugly mess.
I also found a leak in the grab rail on deck as well as a deck crack along an stanchion.
My plan was to remove everything and start re-bedding.
The boat has been covered for nearly two years. I've opened areas of the deck to dry things out. I was very fortunate, this boat was in a charter fleet and many of cleats and blocks were properly re-bedded. I'm crediting the charter company because there are many signs someone did something right (barrier coating on the hull for one ) followed by several owners that were clueless.
I ran across a post raving about Captain Tolley's Creeping Crack Cure and thought I would give it a try.
This first appears as a bit of a short cut but I quickly became comfortable with it since I feel I have any soggy core issues well at hand and this boat is not going to see heavy usage while I own it. Unlike Joe (25yearslater) I am not looking to completely rebuild the boat or elevate it for crossing oceans as I've seen others do.
I traced upstream any leak I noted two years back and guessed at the source. I applied Captain Tolley's magical stuff everywhere I could think the source of the the leak was. It was easy to see the leaks once I applied the stuff. The thin materiel disappears into the crack in a minute or so. It just sits on top if there is no leak for it to enter. I let it sit a few minutes and wiped off anything that did not follow a crack. I reapplied a few days later. Sure enough some of the cracks sealed up completely others took two applications. The best thing about this process is that you can tell when you have sealed up the crack. It just sits there once it has no place to go.
The test: I removed the tarp last week and It's been raining on and of since. I went to the boat this morning during a very hard rain. Boat is absolutely dry below. I squirted dish soap over the entire deck to help the rain wash away some dust leftover from the hull blasting. This of course lowers the surface tension of the water and would allow it to find the smallest leak. Still nothing. I'm sold on this product.
