Maine Sail,
First of all, thank you for all of your valuable information. I've got a 2003 C310 that I'm about to do a packing change on the stuffing box--plan to use GFO. I'll be pulling the boat for a day or so for bottom paint, so I've got only limited time out of the water and want to be ready. I've studied your article and have just one question. You show cutting the ring(s) on a temporary shaft, and cut on a diagonal. Do you cut both ends of the ring at the same pass? Seems like if you do the ring will be too long. Perhaps it compresses or I've mis-understood. See attached diagram. Alternatively, do you cut one end at a time on the 45-deg diagonal so they are aligned on the shaft? Thanks in advance,
Gary
Gary
