Was I lucky or what? Forestay failure!
Actually installing the new rigging is a DIY job. Box up the old rigging send it out and have it duplicated. The only issue may be the forestay, because the current forestay is integrated with the fuller. In that case your suggestion of ordering it long and using a Sta-lock would work.
I've used Rigging Only several times to replace rigging. They do good work at a fair price with a pretty quick turn around time.
I put the new stem piece in today and it seems to fit perfectly. ...
Good on your fabricated. Out of curiosity did they bend the SS stock? Is there a concern about work hardening? When installing I have some question about torquing the strap down if it's not a passive fit?
Jan 7, 2011
6,013
Oday 322 East Chicago, IN
Murphy's Law corollary is that while up the mast a dropped wench will break the Binnacle Compass before falling overboard. At least you were spared that. But you were flirting with the esteemed Murphy.
When I was putting the new chain plate on today, which required the removal of 6 bolts in the anchor roller, I opened a big golf umbrella, turned it upside down and tied it below the anchor roller! Hoped it would catch whatever I dropped !
Jan 7, 2011
6,013
Good to hear a positive comment about Rigging Only…they see,m to have the best price on a Profurl unit.
thanks,
Sep 24, 2018
4,788
Catalina 30 MKIII Chicago
D&R was more reasonable than local riggers for my O'Day as they build in quantity. Chicago Marine rigging met me halfway. Don's customer service is top notch
If memory serves me correctly, @Maine Sail has an article or two on terminating VHF connectors. I ended up doing mine with a butane soldering iron as it was the only thing I could get on short notice before launch
Jan 7, 2011
6,013
They did bend it. I don’t know about work hardening, but there some tool marks at the bends. The old one looked very similar (same tool marks).
I am going to try to send the old parts to @dLj for analysis. Not sure how helpful it will be, but work getting a close up of the break.
But the old one lasted 38 years. I will be dead before it fails the next time ( well, I won’t be sailing anyway).
And now that I know this could be a weak point in the rigging, it will get inspected regularly.
dLj
Mar 23, 2017
5,233
I look forward to getting the parts. I'll give a report back once I get them and see what the best way to manage this design moving forward may be.
The bending of the new part caused a crease along the tension side of the part - Greg sent me pictures. That bend should have been done using a radius mandrel. Apparently the old part has this same crease from original manufacture. Looks like it's the likely cause but I'll know more once I take a look at the actual part that broke.
dj
Apr 8, 2010
2,254
Hope you (or someone) did a mirror polish on the new SS part.
dLj
Mar 23, 2017
5,233
Not at this point but Greg could still get it polished if he wants to. When I get the old parts I'll look to see what kind of finish the original had - that potentially could be another aspect of the breakage.
dj
Jun 25, 2004
672
Hunter 306 Pasadena MD
I'm a bit late to the commenting party here, but as many have said: good job dealing with the emergency, Greg! I also appreciate it when people risk drawing negative comments by posting about a problem, for the benefit of helping out their fellow sailors.
You may recall that I had my standing rigging and all electrical wiring/fixtures replaced this spring by a professional rigger in Annapolis. I chose not to attempt it myself mainly because my mast has never been down before (22 years), our yard crew (while great guys) don't seem competent to do this, and I've never seen it done in person so I wouldn't know how to direct them. In the mid-Atlantic where I am, few people drop the mast and almost no one does it every winter, unlike in some yards up North.
I liked the riggers I used, but I have to admit that I didn't explicitly ask them to check the stem fitting or chainplates. Maybe they did and maybe they didn't. I'll have a close look at the stem fitting, but I'm going to guess that it might be hard to see a fine crack in the SS when hunched over the bow: a 43 year-old engineering degree hardly makes me an expert in metallurgy. (On the other hand, I've probably bent hundreds of metal things back and forth until they broke, so maybe I _am_ an expert! At breaking things...) My chainplates are 90% external, so that's a good thing.
A comment on the VHF cable soldering: I had my cable and antenna replaced by the riggers, and this was the only thing about the re-rig that didn't go smoothly. When they were done re-stepping the mast and tuning the rig, and were packing up, it occurred to me to test the VHF radio. No signal whatsoever. I told them about it, and the lead guy was a little grumpy about it at first. But I told him it had worked perfectly last fall before unstepping the mast, so it needed to work now. They said they'd check that there was continuity between the cable end fitting at the base of the mast, and the antenna at the top, but the parts inside the boat were up to me. No complaints after that, but it took them like an extra hour and a half to figure out the problem. It really gave them fits. The owner of the rigging company ended up calling an electrician friend for advice. They sent a guy up the mast, and he sat up there for more than an hour as they did test after test, and re-soldered the connections. Finally, it tested good and the radio worked perfectly. I believe the problem was the solder joint up at the masthead, so my take on this is that these guys do this all the time, and it seems like it's not necessarily all that easy. I'm good at soldering circuit boards (built a Heathkit TV, oscilloscope, and multimeter back in the 70's), but I've never done coax, so I have no insight into how it's done and what can go wrong. The riggers used a butane torch up on the mast to do it.
Likes: BigEasy
Jan 7, 2011
6,013
Hey Jay,
thanks for the comments. My marina doesn’t normally pull mast either, but in talking to them, their forklift is plenty tall to pull the mast with the boat in the water. I have never done it either, but my spar is fairly short so I decided to give it a try. I had a few guys out to help me on the boat and the marina guy operated the big forklift (that they use to move in and out of the dry stack building).
This will a good chance to learn a lot about my rig, where things wear and how to inspect them…and hopefully I won’t have to drop the mast again as long as I own the boat. So while it is down, I will fix or replace as many things as I can.
Cheers,
Likes: BigEasy
Jun 25, 2004
672
Hey Jay,
Cheers,
I wouldn't say it's dangerous to do the rigging yourself: I just wasn't up to it. If I were doing it, I might try to test the wiring (VHF, lights, wind transducer) before stepping the mast. Maybe if you can lay the base of the mast next to the mast step and hook things up as a test, it would save you a trip up the mast. Good luck with it!
Regarding how many boats still have the original rigging, I'd guess it's more than 95% of all 20+ year-old boats. This is based on reading boat listings on yachtworld. Many boat listings don't mention anything, but when they do have a nice, careful list of recently replaced equipment with dates, it almost never includes the standing rigging. The listing for the 25 year old Catalina 380 I went to look at in VA last weekend didn't say anything about the rig (which was fine: I assumed it was original), but the broker told me the forestay had been replaced. This was an owner who apparently had the yard do things whenever they recommended something, and one year they had recommended the forestay. No idea if a professional rigger had ever looked the rig over. If I do buy a new (probably 20 year old) boat, I'll probably have the rig replaced in the first year.
Apr 8, 2010
2,254
One bit of info about standing rigs -- there are industry standards, depending on venue and latitude for every sailing area. You can ask any professional rigger. For amateurs like me, about 20 years in a fresh water environment is a good max. I last had our standing rig replaced in 2021, and that was the third new rig on our '88 boat.
The comment about "listings" is spot on, and the other even more expensive "elephant in the room" is the required re-bedding of all deck fittings at the 25-to-30-year point. Key word is "all". I know of several boats in our YC that have done this besides us. It's the major reason that older sailboats depreciate to zero or negative numbers, and is totally preventable.
Of course having a mast go OB can be quite traumatic as well! I was crew on another boat where this happened at sea, and the memory is strongly imprinted! :)
Jan 7, 2011
6,013
As an update, after getting some comments about the finish on my new bow chainplate, I took it back off the boat this morning to try and polish it up some. I have not found a local company that does polishing, and I have a very limited time to get the thing put back together...
So, in my basement workshop, I did the best I could with it... I will say that it is much easier on the hands, you cannot "feel" the mill finish, and the edges are less sharp than they were. It is certainly not a mirror finish, but I hope it is better than the original "mill finish" that it had when I picked it up. It makes me feel better knowing it is smoother, even if not polished to a mirror finish. If I can find someone to polish it in the next week, I will try to get it done... otherwise, this is as good as it gets.
Hauling Tally Ho out on Wednesday now, and should get the mast stored beside the boat on some saw horses. Still haven't gotten an estimate from the rigger, but started making a list of all turn buckles, toggles and other fittings that will get replaced. I need to get the mast top off to see how the 2 shrouds attach INSIDE of the mast.
You might see if a shop can dip the part and passivate it.
I did that after polishing my chain plates.
dLj
Mar 23, 2017
5,233
I had to lookup passivation. This is what I found: Citric Acid Passivation of Stainless Steel
One can buy citric acid powder from a home brew and wine making supply, it may even be on the shelves at WalMart. It sounds easy to do yourself, with minimal skill and time.
-Will
@Will Gilmore that is an excellent article on using citric acid passivation. I actually carry Citrisurf 2210 on my boat. It's a gel rather than an immersion liquido so I can apply it on parts on my boat while being on the boat. For example I've passivated my lifeline stauntions on the boat without having to remove them. If I buy stainless hardware, I'll passivate them before using them.
Citrisurf is an excellent product. I think you can buy it in Amazon. But buying an inexpensive citric acid as you've suggested would work just fine - that article was written more for production type environments. A number of the cautions are aimed more for continuos use baths.
You do have to be sure the parts are very clean before putting them into whatever citric acid bath you are going to use. And you them do not touch them with your hands to put in the bath. Finger prints don't go away in the bath...
dj
My rationale for utilizing the machine shop? They were already engaged in another project. They had the chemicals, temp controlled tank, and said sure will dip your parts, no problem. Convenience.
Oct 6, 2007
1,180
Hunter H30 1982 Chicago IL
Wow. That situation is my worst nightmare. Very lucky the mast didn’t come down. You handled it well.
My 44 year old boat, which has always been on Lake Michigan and is stored outdoors, is on its third set of standing rigging. I had it all replaced in 2021 after finding a couple broken strands on two lower shrouds. It was probably about 18 or 20 years old.
I’d never imagined a stem fitting failing like yours did and will definitely be taking a closer look at the design and condition of mine now.
Jan 7, 2011
6,013
Hauled Tally Ho yesterday, then lowered the mast down to some horses on the ground.
Started determining how the shrouds and stays are connected to the mast. Removed the masthead and confirmed 3 broken sheaves, was able to remove the shroud pin that attaches the 2 shrouds to the mast and got the shrouds loose. Removed one spreader to free the shroud and to remove the pins for the 2 lower shrouds.
A very interesting jigsaw puzzle!
I have the STB shrouds off, coiled and labeled. Will work on the Port side on Friday and will try to get the old furler off so I can get the forestay off. Back stay has a ball stem fitting and should be easy to pull.
I also need to re-install the bow chainplate. Interestingly, I spoke with Bay Sailing Equipment yesterday about new rigging. My inquiry to Rudy at DR Marine came back that DR could not help with the 322 rigging, but that Bay Sailing Equipment provided the rigging for the 322. When I spoke with Dennis at Bay Sailing and explained the chainplate failure, he surmised that the original design had been modified. I sent him some photos of the failure. And will follow up on what the original design looked like.
While I could just have a rigger come out and measure and install the new rigging, I am a bit of a DIYer and enjoy seeing and understanding how this all ties together.
