Oh my. That's a scary thought. It would certainly make for a bad day.There is some risk management balance there. Exhaust hose is much more robust than most other drain and intake hoses, so there is less likelihood of failure there. Also if you ever forgot to open an exhaust seacock before starting the engine it would make for a pretty bad day, worse than if you forgot to open any other seacock. I think (though I haven’t read the spec myself) that ABYC exempts exhausts from the seacock requirement for these reasons.
Thanks for all the feedback so far.
I’m going to go ahead and replace the two hoses in the aft compartment with robust marine-grade hose and double clamps set 180 degrees apart. That should hold up solid for the next couple years until the next haul-out.
For the seacocks, I’m planning to swap in brass (edit: I meant to say bronze) for four total: the galley sink, engine intake, marine head sink, and what I think is waste discharge. I believe the engine intake is half inch, the galley sink and waste discharge are inch and a half, and the head sink might be three-quarter or maybe even half inch—I’ll double check, but if anyone knows the correct sizes on a Hunter 30, I’d appreciate the confirmation.
A few of these had no valve at all, including the marine head sink discharge, which surprised me. I’ve attached a few more photos including the engine intake.
Appreciate all the help and opinions so far—grateful to learn from the community.
