Congratulations, Mark. Sounds like a good plan. Looking forward to your updates on progress and splashing the boat.
Yep, probably like this:It really is hard to find good help! I can picture the discussion as the boat is being built!
I'm just glad I have the time now to fix it right! Half-ass is not in my toolboxthat's an extra job you didn't need right now. and you don't want to slap the repair together b/c someone down the road will presume the boat hit something submerged if it looks like a half-ass repair. kind of like 2 steps forward and 1 back right now. but you are persevering very well, indeed! I'm learning a lot from your posts.
No mushrooms, but I don't cringe and hold my nose when cleaning the litter boxes anymore!keep looking.....you could have some really good mushrooms in there!
This was enlightening! After reading through your troubles I rethought what might have happened to mine. It's possible what I've encountered was someone's attempt to fix the false bilge. I have a plan, read on!Mark
If you get time have a look at the false bilge posts for the hunter 31 and 34. We have had the same problem. Some good info in there on clean up and repairs. You are doing one hell of a job.
I didn't know about the bilge construction either but it's on the way to being better! I'm not sure I would call this quality control as much as real world limitations of the molding process back then. Sure, they could have tested the masters for a better fit but we are talking cost issues vs. remaking an entire mold. Back then the ideas about boat usage were a bit different than now and I bet that back in the day Hunter never thought these boats would even still be around.Mark,
After reading your post and seeing your photos it looks exactly like the false bulge and the poor quality control issues Hunter had when they bonded the liner to the hull.
I never new that the h40 was done the same way.
Lots of h34 & h31 owners have done mods to correct this issue.
Awesome job you are doing on you restoration.
Wish you worked for Hunter back on the 80s era and I'm sure the a lot of the stupid things done on these boats back then would have been eliminated.
What you have done so far is absolutly amazing.
The plan is to glass directly to the hull section of the bilge and bring the glass over the sides to tie into the flat portion of the liner. Basically eliminating any voids up to the glue joint so there will be no need for limber holes except at the aft end - the gap there will have to stay. I'll post pics of that area tomorrow to show why and there will have to be limber holes or a drain port of some kind there. Since the glue joint around the bilge and liner is intact I shouldn't lose any hull integrity. That area of the hull is the strongest part of the boat anyway so probably not adding any measurable strength but that's not what I'm shooting for.I am curious how you plan to proceed? I am guessing that you will glass the bottom and sides of the bilge and connect to the liner. Will you be adding pipes or limber holes to connect the area between the floor pan and the hull?
My only concern with that plan would be condensation on the hull or liner that has nowhere to go. My thinking is that if there is a void, it should have some way to let water get to a lower point (even if you think it is sealed) I am sure that Hunter thought that there system would "prevent" any water getting to the area below the false bilge and we know how that turned out.The plan is to glass directly to the hull section of the bilge and bring the glass over the sides to tie into the flat portion of the liner. Basically eliminating any voids up to the glue joint so there will be no need for limber holes except at the aft end - the gap there will have to stay. I'll post pics of that area tomorrow to show why and there will have to be limber holes or a drain port of some kind there. Since the glue joint around the bilge and liner is intact I shouldn't lose any hull integrity. That area of the hull is the strongest part of the boat anyway so probably not adding any measurable strength but that's not what I'm shooting for.
Got the bilge ground back to good glass and the first layers on in the corners (no pics yet). The first few applications of glass will be fixing the radii of the corners so the final layup will go smoother.
Cheers,
Mark
Well, if there is any condensation it has nowhere else to go! Like you said, if there is an air gap it will just build up moisture again and eventually get packed with goo.My only concern with that plan would be condensation on the hull or liner that has nowhere to go. My thinking is that if there is a void, it should have some way to let water get to a lower point (even if you think it is sealed) I am sure that Hunter thought that there system would "prevent" any water getting to the area below the false bilge and we know how that turned out.
