More great work, Mark!
So, you going to rename it "Survivor" ? ;-)
Haha! Isn't it bad luck to rename a boat unless it's for a new owner? I do like "phoenix" tho
That's as good an explanation as any I could think of. I was alone and thankfully the rollers I used compensated for the lack of tipping. Each successive coat got smoother and smoother and now with a good buffing (when the paint is cured!) it will truly meet my final goal - so bright and shiny you can't get within 10 feet without being blinded! Can't see any booboos that wayBeautiful job Mark. I have roll and tipped with both Brightside and Perfection and they are both very user friendly. Were you painting by your self or with a helper (or 2)? I found that I could not get any good results with the tipping when working alone. I then tried it with my wife tipping right behind the final roll and it worked much better. I basically found that the time that it takes to set down the roller and pick up the brush was too long.
No. But it will require a considerable atonement to the gods of the sea... Expensive drink, first born, nude ritual dancing... who knows with a god.bad luck to rename a boat unless it's for a new owner
I think you’ve just about surpassed your out-of-pocket maximum for bad luck. Name it whatever you wish.Haha! Isn't it bad luck to rename a boat unless it's for a new owner? I do like "phoenix" tho
You *had* to bring up nude dancing again. I thought you had learned your lesson from last time....Expensive drink, first born, nude ritual dancing... who knows with a god.
+1... I look forwarded to seeing pictures of you out sailing her.
Thanks! I was told when I bought the boat that the sugar scoop was a factory option but that info came from the PO, so who knows. There may have been an aftermarket company doing such things back then. I do know it was one of the boat's selling points for me and it has been a really nice and useful option. I think it's better than a lot of the current boats that have transom steps because there is "maneuvering room" on the scoop.wow is all I can say ... I had a 1985 Hunter 40 in my past it's always been one of my favorite boats (mine didn't have the sugar scoop transom I assume that was an after market addition) Anyway, I have been following your story with interest, amazement and memories of work on my 40. Then and even today just having to wax the hull and paint the bottom of my boats sets me off complaining about the amount of work required. Next spring all I'll have to do is think of you and it will be easy to tell my complaining mind to shut up and get on with it. Good luck with the rest of the project and hang in there ... I look forwarded to seeing pictures of you out sailing her.
	Looking great Mark. As for the stainless, have you ever tried Wichinox Passivation jell?Re-installing parts & pieces:
...Lastly, I reinstalled the fuel and water tank vents and the grab rails. The rails had quite a bit of staining but I have found that Turtlewax metal polish works really well at removing the rust stains and giving the stainless a protective coating, so the rails got polished before I mounted them. Done for the day:
Mark
Thats close to the same set-up as Catalina ladder steps. They are riveted. Never a problem.you have quite the work ethic!
you think the foot steps will stand up to off center loads with only two screws?
I would like to see some bracing under them to stop any rotation without relying on the screws
That stuff is very similar to what guys in the beverage industry sometimes call pickling paste. It's an acid that eats the free ferrous molecules out of the surface of the stainless. You need to be a little careful when using it & you will want to wash it off as quickly as possible if you get it on you, but, when properly used, it does greatly improve the corrosion resistance of many grades of stainless. It will probably surprise many people to learn that properly passivated 304 or 18-8 actually rates much higher on the nobility scale compared to unpassivated (active) 316. http://www.duncanbolt.com/images/metalschart.pngAs for the stainless, have you ever tried Wichinox Passivation jell?
https://www.fisheriessupply.com/wichard-wichinox-stainless-steel-etcher-cleaner
I think they'll be ok - the step pads are fairly thick in the center and are contoured slightly so they are not flat across the top. Time will tell. Next engineering change if these don't work is to fab some steps from stainless but I thought I would try the low tech route first.you have quite the work ethic!
I got them from Catalina Direct.Thats close to the same set-up as Catalina ladder steps. They are riveted. Never a problem.
I had never heard of this before - intriguing! I went to the link to get some but they are out of stock. I'll search for another source.That stuff is very similar to what guys in the beverage industry sometimes call pickling paste. It's an acid that eats the free ferrous molecules out of the surface of the stainless. You need to be a little careful when using it & you will want to wash it off as quickly as possible if you get it on you, but, when properly used, it does greatly improve the corrosion resistance of many grades of stainless. It will probably surprise many people to learn that properly passivated 304 or 18-8 actually rates much higher on the nobility scale compared to unpassivated (active) 316. http://www.duncanbolt.com/images/metalschart.png
	West Marine carries it, at a price.I had never heard of this before - intriguing! I went to the link to get some but they are out of stock. I'll search for another source.
