http://shop.sailboatowners.com/prod.php?6756/Telescopic+Spinnaker+Pole
http://www.seldenmast.com/files/1388402617/excerpts/595-808-E-142-142.pdf
This product is designed to be a spinnaker pole at the Design Length and it has 2 whisker pole settings. Read the info on it. I bought the one that is shortest for my boat so the spinnaker setting is just under the J dimension. I also did this for less weight. There are 4 positions: stowaway, spinnaker, whisker 1, whisker 2. I think the 14.7' length is adequate for wing on wing even with my larger genoa. On your boat, I suspect the model that starts at 9.8' length and ends at 17.2' length will work best. I almost did that myself because the spinnaker setting would be just slightly longer than J and if I really wanted to be race legal, you can use the stowage length (the shortest setting). Some folks don't like the push button settings because it can be dangerous to the finger tips. But OTOH, you shouldn't be adjusting the whisker pole under load anyway. Personally, I think this product is designed very well, it is plenty sturdy (if not a bit heavy), and I think that 2 whisker pole settings is all that is necessary. I don't like the twist lock features on other adjustable whisker poles and unlimited setting adjustments isn't necessary.
Don't worry about the "out of stock" notation. They will probably have this for you in less than a week.
