Single handing
When one is “running” does the wind dictate the side one sets the main? Or can one decide? If I have my preventer coming down the Starboard side, can I always put the Main on the Port side?
Thanks
Ric
Other than the nicely detailed answer David gave you, the tack you were on before turning DDW usually determines which side the boom is on when running DDW.
-Will
May 1, 2011
5,521
Pearson 37 Lusby MD
Course, speed, position, hoist sails, douse sails. start engine, stop engine, putting reefs in the main, shaking reefs, etc.
Nov 1, 2021
132
Hunter 19-2 Ashland WI
Do most of you sailors have adjustable topping lifts or are they fixed and are disconnected after the main sail is hoisted?
Thanks
Ric
Yes! Or both. I'd say more or less evenly.
Adjustable can be annoying because the tail hangs down. You can stuff into the sail cover but it tends to escape. You also might have more hardware flapping around up there.
Fixed are usually attached to the backstay. Depending on the boom length they can be in the way. And, in most cases you want to disconnect the TL before hoisting the sail. Imagine the SS if the wind fills the sail but you can't release the TL that is attached to the backstay!
On my H356 the topping lift went to the masthead from the end of the boom and down the mast to a cleat near the deck. That was a pretty good arrangement.
You also have the variable of a Bimini if one exists.
Jun 12, 2021
300
Hunter 240 Aqualand Marina, Lake Lanier
My Hunter 240 has the out haul, reefing line, and topping lift all in the boom. The topping lift comes from the mast head, it is wire, and transitions to line several feet above the end of the boom. It enters the end of the boom over a block and through a jam cleat at the goose neck. I like it. It took me three months to figure out all the lines after I bought the boat.
Nov 1, 2021
132
On your Hunter 240, do you have a loose footed main? Or do you use the bolt rope groove?
On my Hunter 19, I have three sheaves at the end of the boom. My out haul is the only line that uses these sheave. The other two are empty. The boat came without any reefing lines. The topping lift was tied off at the mast head and tied off at the end of the boom. This next year, I will be rigging the topping lift through the boom and also rigging reefing lines as well.
Thanks
Ric
P.S.
I am looking at seeing if I can convert my main to be loose footed. The main runs up the mast on nylon slugs. ( I think that is what they are called)
Nov 1, 2021
132
Another question.
When you wash your boat:
Do you just use a pressure and plain water?
Do you use a pressure washer with soap? (Bio-degradable)
Do you wash the boat with a deck brush and soap and then rinse with a pressure washer?
Thanks
Ric
Another question.
Thanks
Ric
We use boat soap and a brush, rinsing with regular hose water. If using a pressure washer extreme care must be taken not to get too close to the surface and not to get near any kind of bedded hardware, as the pressure can cause leaks through the bedding.
To protect and help keep the surface clean we use wax on all smooth surfaces and Woody Wax on all non-skid. The Woody Wax does a good job of repelling dirt without making it slippery.
Nov 1, 2021
132
I looked up Woody Wax on Amazon, there appears to be 2 kinds, A plain Woody Wax and a Tower Woody Wax. What is the difference?
Is there a specific non-skid Woody Wax?
Thanks
We just use the plain Woody Wax. Looks like the Tower Wax is more oriented for Tina towers and things like that.
And a little bit does go a long way.
Jun 21, 2004
3,196
Beneteau 343 Slidell, LA
Yes Woody wax is great for nonskid. Not slippery after it dries, even when surfaces are re-wetted with water. Just be careful when applying because it is slippery as ice until it initially dries. It seals the deck for approximately 6-8 weeks and makes clean up of bird droppings, etc very easy; looks superb also.
132
Curious, the biggest problems we had last season on the boat were spiders. They got into everything. I could clear the boat of them and the next day they were back in everything. Wondering if it was just around Lake Superior?
Cellar spiders (aka daddy long-legs)? They are prolific web builders.
Removing cellar spiders
Removing their webs encourages cellar spiders to move on to a more productive place. Limit cellar spiders' food sources, by using pet and people friendly insect prevention and control measures. Reduce the humidity in your home or business by using dehumidifiers and making sure there is proper ventilation.
-Will
Not just Lake Superior. Our town and marina have them in droves as well. Best option we’ve found is just a duster on a handle to go around each morning and clear out all the webs. That only takes a minute or two and keeps them out of our way pretty effectively. The worst is taking down the dodger and Bimini at the end of the season. That’s like something from a horror movie with the spiders dropping out of the zipper pockets overhead.
132
When I put “Rhapsody” to bed for the Winter, on her trailer. We distributed two boxes of dryer sheets in the cabin. I do not remember the specific brand. Hoping that will keep the mice at bay. (I think someone here told me about using them.)
Nov 1, 2021
132
I just watched a video where the captain cleaned the water line staining with “Bar Tender’s Friend” and a sponge. Is that not pretty gritty to use? With the grit in it, one would have to apply wax right after?
Thanks
There have been a few threads about BarKeepersFriend in the past. The consensus is that it is effective, mostly because of the Oxalic Acid as its active ingredient. Other products are available with oxalic acid and without the grittiness, or you could get oxalic acid itself to dilute. One such discussion - oxolic acid
Nov 1, 2021
132
Merry Christmas to you all! May you have a most blessed time with family and friends
