Hurricane Dorian <-- TS<--TD 5 <-- Invest 99L
JamesG161
Feb 14, 2014
8,078
Hunter 430 Waveland, MS
You are implying that the Antilles Current (variable) and the Gulfstream (2.5 knot average) won't be replenishing that heat pretty quickly? I'm not sure I'd take that bet. lol
So to show @capta good point on the Gulf Stream, here is a graphic update to my post #74
I like to think of the Gulf Stream as a Heat Pipe line, fast and full of Heat from the south Caribbean Fuel Tank.
The big difference is the Storm Surface Area of Heat Fuel Removal versus the replenishment by the Gulf Stream.
Two other Keys to lowering 2019 season intensity
1) many small Gulf disturbances that rain a lot
2) very "quiet" Sun and low Solar activity;)
3) Storms mix up the deeper Heat, blending from cooler temperatures below.
Jim...
capta
Jun 4, 2009
5,091
According to that, the Abacos area is already back to being very warm. In most cases the tropical cyclonic events I've experienced have been followed by extremely hot, still and humid conditions, which must also replenish the heat a bit more quickly.
JamesG161
Feb 14, 2014
8,078
Heat is Energy content. Even cooler waters have Heat, just cooler.
____
Very true, it is Summer still.
But...
Heat removed.
That chart is what Meteorologist use to study Sea Surface Temperatures Variations versus a agreed upon standard.
That Standard is the Average of the period 1981-2010.
Why that time range?
Satellite measurements. Earlier years not so globally done.
Heat content versus SST Anomalies.
This is done by Two Satellites used together since about 1980.
Look at the Caribbean Fuel now. But note less influence by the Gulf Stream.
Jim...
capta
Jun 4, 2009
5,091
Not to be argumentative, just for the conversation, wouldn't you expect the majority of the heat sitting under Cuba around the Caymans and Jamaica to be picked up by the stream and carried north pretty quickly considering the average Gulfstream speed of around 2.5 knots?
I haven't been following this map, so I have no idea what has caused the pause north of Cuba in the stream to create this warm pool.
It must really be killing the offshore fishing in the Keys. Time to get out the flats boats.
JamesG161
Feb 14, 2014
8,078
Absolutely!!
But think like a Diesel Fuel tank. Gulf Steam is draining Heat from the Big Tank [not majority drain tho]. All along the Gulf Stream that Heat is spreading out too.
_____
The spot in Central Gulf is the Heat "Swirl" then the Stream goes around FL. And the Gulf is Very Deep at the return point.
Mixing.
Jim...
Good point Capta... The Gulfstream is a big mover of the Caribbean heat.
But the Gulfstream is not moving at a constant speed it is influened by Low Pressure cells. The cells when big enough and spinning in a counter clockwise direction can influence even the Gulfstream. As seen in image 2 off the Central East coast of Florida. Slowing the stream down to 0.9knt and evening causing it to swirl out and away from its primary route NE along the coast.
Likes: JamesG161
capta
Jun 4, 2009
5,091
Oh, I don't disagree at all about fluctuations in the stream's speed, as I have personally experienced one crossing from the Northeast/Northwest Providence channel to Lauderdale where my landfall was North Miami Beach (where oh where are the smokestacks when you really need them?), meaning no current at all on the trip. On the other hand, coming back from Brazil on my freighter, my original pilot meeting time of about 9 PM at Palm Beach A buoy was pushed ahead repeatedly as it became apparent that the stream was running at around 8 knots!
I just use the 2.5 as an average between Mexico and western Cuba to Cape Hatteras or so. Very general, but serviceable.
It is an ocean and it will be changing. We as sailors need to adapt.
The info was provided to help understand the variances of the current and the Low pressure cells that are stirring up the weather we are all following. It is easy to be wow'd by the surface storm. Dorian was a great example. At the surface it was doing one thing, at 5000 to 10000 feet it was doing something totally different. Why there were so many HH flights to try and understand what the storm was doing. All the while it was changing the under water conditions of the of the Caribbean Heat source for the storm.
The plots give a bit of information about the water currents that influence the area and the weather.
JamesG161
Feb 14, 2014
8,078
Pretty cool use of Windy.com. I will see if i can get the SST Anomaly combined.
Also note that Cool Calm Heat area North of Havana is influenced by the Everglades rain fall run off.
Nov 30, 2015
1,343
Jim/John, What’s up with Humberto? Dorian killed our spring plans for the Abacos bare boat trip. I guess it’s back to the BVI in 2020. Windy.com rules!
NOAA is saying...
"Tropical Force winds and Heavy Rain."
Current path has it running north of the Bahamas on a similar path as taken by Dorian.
Not currently forecasted to have the strength of Dorian. But all of this can change. Follow the advice of your local officials.
