- Oct 22, 2014
- 24,516
Ward, it is about the physics/geometry.
Secure the line ahead of the pivot point. Run the line out to the dock. Then run it back to the boat behind the pivot point.
Pull the line in to the boat and put it in forward and idle. The boat will pull forward til the line aft is at 90 to the dock point. Then the boat will be pulled snug to the dock.
Turn the wheel to point the prop wash away from the dock and the stern will snug up tight and leverage the bow in. Turn the prop wash away from the dock and the bow will move towards the dock stern out. Movement fore and aft is restricted by the line.
The boat side is the height, the line from the forward of pivot point to dock this the Hypotenuse, and the line aft of the pivot point to the boat forms a 90 degree angle to the boat.
It’s the blend of science nd sailing.
