Assortment of cheap fixes on Cat 22
Sep 14, 2014
1,295
Catalina 22 Pensacola, Florida
Pump is one on the boat when I got it, but spout was missing. So I fabricated one out of copper tubing. All the others I have seen had spouts or handles or both too high to allow you to slide the galley back under the stbd seat like it is supposed to. Pix of fabricated spout.
Sep 14, 2014
1,295
Well I hope I do not have to get the boat ready for Dorian over here in Pensacola, course if it gets into the gulf we all suffer along the coast to Mexico.
Sep 14, 2014
1,295
Here is a really simple solution to stuff sliding off the table in the cabin underway. Put a piece of cheap rubber shelf liner on the table, it stays on very nicely and keeps stuff on top of it from sliding (except in extreme conditions , which or course you should have secured stuff for anyway.) Comes in nice colors too!
Sep 14, 2014
1,295
Just a suggestion, I put my extra fire extingusher in a mount on edge of portside aft dinette seat so it is to hand when I use the bistro stove in my pullout galley on the starboard side. Just in case of course! And el cheapo led flashlight on hook next to it for those deeply cooking pots of unkown.
Sep 14, 2014
1,295
Cooking with the original mood lighting of catalina 22, light under window away from stove area, a flashlight is handy to check cooking status in deep pots in dark!
Likes: rgranger
Ah! Understood.:biggrin:
Lazy1
Aug 23, 2019
202
Ericson 35-3 Erie PA
A suggestion I have heard several times is to put the extinguisher at the exit because you should always get to an exit before starting to fight a fire.
Apr 11, 2017
571
Catalina C22 Solomon's Island, MD
Plus - it's also handy to grab from the cockpit.
May 23, 2016
1,024
Catalina 22 #12502 BSC
I keep one there too, and the other in the stbd laz...altho, I wanna get a fire blanket for near the galley...have you ever set one of those extinguishers off? helluva mess to clean up, I'm told...
Sep 14, 2014
1,295
Yep what is the old adage, if it aint broke dont fix it? Unless you are an engineer and want to take it apart to see how it works. Did that with an old mechanical alarm clock when I was about 10 years old, put it back together without about 3 parts and it still works today!
Sep 14, 2014
1,295
BTW when I redid the cushions in the boat I stuck down some carpet in blue color with double sided tape in cabin sole and step down in to the cabin.
Likes: rgranger
Sep 14, 2014
1,295
Yep and weather is cool here, meaning in 70s and no snow (yet).
RussC
Sep 11, 2015
1,735
Merit 22- Oregon lakes
use adhesive backed velcro stuck to the floor and sew std velcro on the carpet back. only takes a strip across each end. works well and makes it easily removable to shake out the dirt etc. :)
Likes: Gene Neill
Sep 14, 2014
1,295
The carpet tape works fairly well, I can remove and clean but mostly just vacuum it.
Sep 14, 2014
1,295
Little update, got cold here, 55 high with light se wind. If wind comes up a bit more may just hoist sail and head out, cool for overnights though., 40s
Likes: Hardhead
