So It Begins: Deck Recoring Project
Mar 24, 2012
70
O'Day 40 BC Coast
Very impressive workmanship!
I need to to replace some core around the shrouds.
Did you consider cutting the top fibreglass off in sections and reusing it?
Likes: Clutch Cargo
May 30, 2006
362
Oday 34 Chesapeake Bay
Thanks nramsey. Small sections may be easier to do that way particularly if you’re planning to replicate the existing pattern. Karma’s deck had so many stress cracks that I went for wholesale removal.
If you look closely at the “gut” pile, you’ll see that many of the sections shattered upon removal. Where the core was saturated removal was easy, but not so easy where the core was only wet. It’s amazing how tenacious even a wet core is.
Likes: eherlihy
Oct 7, 2008
380
Oday Oday 35 Chesapeake Bay
If the new sections are thicker, will it line up correctly with the existing section?
May 30, 2006
362
I’m faring out the differences. Not much more than 1/16”. Where there’s more I’m using strips to maintain the same camber.
In the section that I’m currently working (about the last 8’ on the port side) there was significant difference (perhaps 1/4”) where the cabin meets the deck. In those areas I’m laminating multiple layers of various widths in order to taper down to the rail.
May 30, 2006
362
Greetings, it's been awhile. The weather got colder quicker than I planned, so turned my attention west to ski as well as helped a friend get his boat down the ICW on his way to FL. I was able to finish fiber glassing and fairing the last section of the aft port side. It got too cold however to prime and paint. I did order some accelerator (AwlGrip M-3066) so was able to prime during marginal temps... that stuff works really fast.
To date I've got the first two layers of topcoat down. Next up will be applying the nonskid once I've masked off the non-nonskid sections.
I believe that I'll be finished in another 8 weeks, weather willin' :)
May 30, 2006
362
The saga continues. Last section of the portside masked off and ready to apply the SoftSand non-skid.
... note the unmasked hole. Had a bit of a oopsie when trying to locate the stanchion mount location :facepalm:
Non-skid down, prior to removing the masking tape. I find that Scotch Fine Line Tape 218 keeps the edges crisp. It's expensive so I use a combination of it and 3M Automotive Refinish Masking Tape. Not so pleased with the green and blue stuff, so use it for filler.
The hard part was drilling the 30 some holes for the jib car track and other hardware, in the pristine deck.
Studying Bedding Deck Hardware With Bed-IT Tape - Marine How To want to make sure that it's done right. So far everything that I've used butyl on has been leak free. I've even been using it to plug exposed holes whilst wait to install other deck hardware.
May 30, 2006
362
Had a productive few (dry) days.
Got the shroud U-bolts and deck fills (water and waste). There was no protection for the balsa core, the U-bolts didn’t show any signs of water infiltration, the deck fills however did.
The gut pile grows.
This is the deck with new balsa core and coosa placed where deck penetrations are. I replaced the marine plywood at the cap shroud penetration.
Was able to glass the core as well. I learned the hard way to cover the core ASAP to prevent moisture intrusion into the exposed core from dew and/or rain.
Aug 17, 2010
336
Oday 35 Barrington
I've been away for a while, but THANK YOU @SailingCal21 for documenting this process, and thank you for documenting it here (where it can be searched and referenced in the future) and not on FaceBook. You will KNOW that the job was done right, or you'll know who to yell at for doing a shoddy job. You are also making this less daunting for any of us that follow in your wake.
Questions;
  1. Did you consider replacing the embedded aluminum plates with G10? If I were to undertake this task, that would be my first choice.
  2. Around where the deck fittings mount, I would have placed a ring/bead of West System's Six-10 as a barrier in case of future water intrusion.
  3. Also, way back at the beginning of the thread you spent time and energy cleaning up the old fasteners. Why not simply replace them?
May 30, 2006
362
Welcome back. Thanks for the words of encouragement. It has been a daunting task (on month 13 of a estimated 9 month project ;) ), but I can see the light at the end of the tunnel. I'm trying not to think about the other deferred periodic maintenance projects (bottom painting, stuffing box repacking, fluid changing, etc) till the current task is completed.
Questions;
I left the aluminum plates in place, but will improve the backing by installing 1/4" G10 along with thickened epoxy from the underside at each stanchion base. For the majority of the deck penetration areas I've used Coosa in lieu of balsa to eliminate the possibility of rot due to water intrusion. Originally, the cap shroud and jib car track had marine plywood which I've replaced with the same. After comparing the compressive specs for alternatives, I found that marine plywood specs to be better than or exceed alternatives, they've been encapsulated with epoxy to mitigate rot due to water intrusion. I'd be concerned about using thickened epoxy products as a sealant as it wouldn't have the "self healing" properties that butyl tape exhibits.
I'm using copious amounts of butyl tape around the fittings. I've found it to be the best to prevent water intrusion and to maintain flexibility over time. I've also masked off the areas where hardware is installed so that there's no non-skid under any fitting. My thinking is that the rough surface under each fitting is a source for eventual water intrusion, unlike a mostly flat mating surface
Yes, that was pretty much a waste of time... educational, but a waste. Also, considering that I've added 1/4" backing plates, most fasteners now need to be somewhat longer. McMaster-Carr has been a godsend for sourcing SS fasteners and accessories.
Aug 17, 2010
336
Oday 35 Barrington
Regarding the stuffing box; I replaced my stuffing box with a PSS Shaft Seal in 2011 (02-100-134 $260), and have since (proactively) replaced the bellows in 2019 (07-100-134R $90). I have not had any issues with it at all!
51
O'day 39' 25th Anniversary Mystic, CT
I must commend you on your hard work and dedication to accomplishing this task!!!! I have hired a fiberglass contractor to do this job for me, however, he did not remove and rebed our jib track (which is where we found water intrusion) so I am going to do this part myself. I am in need of guidance as to how to lay out where my jib track holes will lay…. my thought is to race out a template before removal that I will tape down after removing the screws. Any better solutions would be greatly appreciated….
Aug 11, 2011
988
O'day 30 313 Georgetown MD
@Faster Horses I assume the way your track bolts were fastened is the same as any other larger O'day. Therefore there will be holes inside the the cabin where the washers and nuts would have been, unless that too was repaired. It would be easy enough to pilot drill from the inside through the newly laid filler material and come out top side. Then drill oversized, do the usual fill and re drill. Am I thinking this out wrong?
Likes: Tally Ho
May 30, 2006
362
Yes that's the way to do it. However, when I reinstalled the port jib car track (haven't finished the starboard side at this time) I simply drilled the first and last holes from the inside, then mounted the track and drilled thru the remaining holes from the top down. There's about a 10' span so the track can shift somewhat during the top down drilling. Using this method, I was off between the liner (where the larger holes are for the washer) and the bottom layer of laminate less than 1/16" on some holes in the middle, but nothing that prevented the install.
362
Thanks for the encouragement :)
On Karma I found that the core under the jib track was plywood (presumably marine grade) however the adhesive between the plies had long since succumbed to the constant water intrusion. Structurally, the wood hadn't turned to mush (as the balsa core did), however IMHO the plywood core was compromised. I used my jib track as the template and drilled top down once I established a start and end point from below.
May 30, 2006
362
Cleaned up the starboard jib track. Most of the underside as well as the screw holes are painted black. Definitely signs of crevice corrosion on some bare spots.
Ideas on prepping the bare aluminum prior to a coupla coats of black enamel. Or would a coupla coats of 545 Primer be better?
362
Project completed! :dancing:
Project start May 5th 2024
Completion September 7th 2025
Cost of materials: $5k-ish. Being an amateur, I figure that I wasted a good bit (25% ?) of the paint, primer and epoxy.
I figured that the project would take 9 months, in fact it took 15 months... less than twice as long, so I call that a win! I lost a few months due to excessive heat and cold temperatures.
Also, the project would have taken less time had I used other materials, I spent a good bit of time watching paint dry (roughly 16 hours between coats). Had I used other non-skid/paint/primer systems those steps would not have taken so long, however as much of a PITA the AwlGrip system was, I have complete faith that it will outlast me.
