Help Me Understand The Basics Of Boat Battery Charging
Sep 8, 2025
126
Bayfield 36 Lewisporte
The saddle sizes for Yanmar diesels is 3.5". I'd encourage you to not use a dual belt and instead use a serpentine belt. It is very difficult to properly tension the 2 belts as belts are seldom exactly the same size, so one is either too tight or too loose.
And getting deeper in the weeds, do install the Balmar Belt Buddy or similar belt tensioning device. Larger alternators put more load on the belt than smaller OEM alternators. Often the single tensioning bolt is not able to resist the increased load leading to the belt becoming loose.
If you are willing to deal with cross border issues, Peter Kennedy at PKYS.com is an excellent resource, he is one of the most knowledgeable people in the business with fair prices and excellent service from him and his staff.
Thanks...will check it out. Appreciate the info.
Jan 4, 2006
7,769
Hacking a Hitachi alternator works for @Ralph Johnstone because he has a relatively small LA battery bank of about 150-200ah. (Can't remember if he has 2 Group 27s or Group 31s.) His max output of 37a is in the right range for the Group 31s which like to be charged at .2C or about 20a per battery
STOP READING MY MIND ! ! ! It's freaking me out man :yikes: .
Our resident Guru is absolutely correct about my electrical system within 2-3 decimal points and knows more about my system than I do.
One other thing which may rear its $$$$ head is a mechanical supply of cooling air if your engine room is anything like mine. The engine enclosure started life as a Nike shoe box :
The engine has about 1" clearance under the cover which makes for a hot supply of cooling air for the alternator.
Enter the cooling fan which will keep the temperature of the cooling air below the temperature of the block ~ 170° F.
The reduced temperature cooling air keeps up the amperage output from the alt. as the external alt. regulator has a safety feature which reduces the amperage output as the body temp. of the alt. increases.
Likes: GeneraiT001
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Hi, Thanks
Thats what I was looking at - XT-SF-170-DV-KIT :) How can I figure out the spindle or saddle size for a Yanmar 4JHE motor? The "DV" seems to be for a 1-2" spindle?
That is the one with a single foot (SF) and a dual V belt pulley (DV). That's not what you want. Yanmar engines have the dual foot configuration. You should see it clearly when you examine your existing alternator. The XT-DF-170-J10 has the footprint you need and the J10 pulley is a better selection. I think if you want the XT model, you will be committed to converting your entire pulley system. With that size, a single v-belt will wear out belts quickly and leave a mess of belt dust inside your engine compartment. If you don't want to change your pulley system, then I think you need to consider the 6-Series alternators.
My previous owner installed a 125 amp alternator and used the OEM v-belt pulley system. Belt dust created a huge mess. I bought the kit for installing the J10 pulleys and it wasn't a hard job doing the conversion but I did have to buy an expensive prop puller to get the main drive pulley off. So far, it's been a 1-time use out of that tool, but at least I have it for future use :facepalm:. I'm glad I made the conversion because any future alternator purchase won't be limited to one with a v-belt. The serpentine belt is a big improvement. I agree that the belt buddy is also a good improvement to get the proper belt tension. Everything we are talking about requires money spent in a cascading series of improvements. It's pretty much unavoidable. When you make a decision to use your boat in a certain way that leaves you more vulnerable to weaknesses that can lead to trouble, you have to be aware that there will be cost consequences. If you tether your boat to a dock, you can get by with far less ...
When you read about the experiences of sailors who leave the dock behind, you will realize that refitting the boat is a significant project with significant costs.
Oct 26, 2008
6,432
BTW, when I converted to the J10 pulley https://www.westmarine.com/balmar-pulley-conversion-kit-18089193.html?utm_medium=cpc&utm_source=google&utm_campaign=GGL_PLA_Engine Systems_High Margin&gad_source=1&gad_campaignid=22691717993&gbraid=0AAAAAD_lEeqyuhuJEezfWQKn10TKkQXH8&gclid=Cj0KCQiAiebIBhDmARIsAE8PGNIG1jsG6NO8iaTOakhSo0x-M5QYtNi1CEyFjGj02uSW1qXuJk4aOwYaAtsvEALw_wcB I quickly realized that the outermost pulley rubbed on the inside of my engine box and quickly wore a groove in the fiberglass at the inner surface of the box. It made one helluva noise and filled the air with the smell of scorched fiberglass before I realized what the chaos was about. I made a 1.5" shim around the box to accommodate the new pulley dimensions. The adjustments never end!
The kit shown above says it is for Yanmar 4JH model. If you convert the pulleys, make sure you get the correct conversion kit.
126
Thanks for the info on getting the right model of alternator. Hope getting the pulley off will ne a snap (LOL...fingers crossd)
Listen to the comedian Jimmy Carr and you would never ask that question.
If you ask a Navy man, they would say, No problem. Just use a big hammer.
Oct 26, 2008
6,432
Yes, I used a battery powered impact driver to remove the pulley retaining nut when I rebuilt my alternator. Nut & pulley came off easily.
It was the gear case pully that was difficult to remove when I converted to the serpentine pulleys. If I remember correctly, the nut came off easily. The pulley had to be pressed off and that was a bit scary even with the prop puller.
The varies with the motor type. On my Yanmar 3JH2e the pulley slid over the old pulley and bolted to it. Same with the water pump pulley.
May 13, 2013
21
Hunter 336 Windsor
Let me offer some reality as to what is REALLY going on in your existing charging system. You're not even in the right ballpark and that's why your results in charging are so poor. Same as mine used to be.
Like you, I also have a Hitachi model LR155-20B 12V 55 amp alternator. This is an internally regulated alt. which puts out a maximum of ~12A bulk charge to any number of batteries all at 50% state of charge (SOC) and the alt. was still cool. Once it gets up to an operating temperature of ~170° F and the batteries with an inceased SOC, you sit at ~ 8 - 9A. This rarely gets you much over an SOC of 80% after running on engine all day.
I installed a Balmar ARS-5 external alternator regulator after the boat was about 10 YO and went from ~ 10A charging again at 50% SOC to :
That was >250% increase in bulk charging and a minuscule fraction of the cost of an LiFePo upgrade. I've never had a glitch out of the Balmar ARS-5 and the little Hitachi 55A supplies all of my electrical needs including a refrigerator when on the hook for a few days.
Maybe a few too many new electrical terms and concepts thrown in there for you all at once so don't hold back with any questions.
May 13, 2013
21
Hunter 336 Windsor
Hi,
My problem as well, as I have never used the boat in any capacity yet and won't be able to for the next 6 mnths as it is out of the water. Ideally, I suspect, I will be putting in ~ 400AmpHrs of LiFePo for the house + 100AmpHr La for starting. Sounds like it is not a simple affair and will most likely be needing an electrician if I can't figure out the safe way to get this all connected. I only have a 100watts of solar (thats the first thing I wanted to upgrade to 400watts - of course for that I need to build an "arch" of some sort to support it). I don't think the OEM Hitachi 55A alternator will be suitable and will probably have to upgrade that to at least 100A?
As an aside, is that "smart" Victron DC-DC charger a good way to charge your LiPo's from the LA battery? I guess I'd be lowering the charging rate down to about 20Amps if I still have the 50A alternator?
Oh yeah, there is a 1000w inverter but it is not connected but I think I would want at least a 2000w inverter for AC anyways...so thats on the list as well :)
Im running into the same situation with the 55amp Hitachi...im worried the 40amp dc to dc charger for lifepo 280ah battery i bought isn't ideal. The renogy 30 and 50 amp chargers are adjustable..my luck, the 40 amp I bought is not..the model is - rbc40dis
You’d probably be better off with an Orion XS that could be dialed down to 30A. They’re known to run much cooler and more efficiently than the older Orion models. I don’t know how they compare to Renogy in that regard.
