Merit 22 owners
Los
Jan 11, 2024
11
Merit Marine Merit 22 Mission Bay, San Diego
I just make a large loop under the lower shrouds. As soon as the mast is up and forestay connected the loop falls down when you loosen the main halyard.
Hi Digger1. If the loop falls down, do you somehow put it back up when lowering the mast? or do you use the jib halyard or something? Interested.
Los
Jan 11, 2024
11
3. No bilge I'm aware of, but access port forward of the keel.
Good answers from Digger1. I would add that when I had Pressure Drop slipped for a couple months, I would routinely get water under the rear left seat that I mopped out with a rag from the access. When I sailed her hard, I also got water under the forward seat that I mopped out with a rag. It seems like these two areas are isolated and that the forward leakage came up from the trunk somehow when heeling hard under a fresh breeze. I am trying to figure this out as well. I recall a post somewhere where someone said the Merit 22 is prone to leakage and you should have an auto bilge pump. I do not know where this person located their bilge and will be tracking replies for insight.
RussC
Sep 11, 2015
1,615
Merit 22- Oregon lakes
Water does tend to come up the trunk whenever you're moving and the keel is even slightly raised. I made a gasket out of thick neoprene and glued it under the keel cap to cure that.
Los
Jan 11, 2024
11
RussC: Lots of ideas in this one pic. 1. That gasket is much thicker than my 1/8" Tk gasket. TY for the idea. my keel bumps around so much that it easily leaks. 2. I also like the electric winch setup. very tight. Why not run it through the third pulley set to lighten the tension? It would go slower, but I think I would want that. 3. Is the hanging block so you can use the portside winch to raise and lower it? 4. I like the white bags on the seat that is too small to be useful as a seat anyway. 5. I see the shackle next to the forward facing seat on the trunk to lock the keel down. Mine has a hold drilled through the top of the trunk. I had to break out the previous owner's fiberglass job that closed off the hole in the keel to make this work. 6. the cushions are dated. My wife used watered down latex paint to paint over the pastel flower pattern on our cushions. It came out good for us, but I don't see how it would work with yours due to the loose texture. aaaand 7. I like the solid hatch cover. I put a cut up political sign over mine to keep the sun out but this looks better. What did you use? THANKS for sharing this!
Los
Jan 11, 2024
11
I think almost everyone here would kill to have a copy of the manual.
Personally, I would not kill for it, but I am very interested in getting the manual and the fiberglass bible that is mentioned in this forum. I am grateful to have found this forum! This is my first good sized boat and while I am handy, this collective experience and guidance is very very helpful. I would be very interested in a Merit regatta to Coronado this summer (2025) or whenever. If anyone likes that idea, please comment. Even two boats would be better than one. I think we would want to sail out of Long Beach and run straight across.
RussC
Sep 11, 2015
1,615
1: the top of the trunk is so irregular mine wouldn't seal with the thin gasket. 2: winch is a cheep Harbor Freight atv winch and works great. I had it in the third pulley but it was too slow and the winch has plenty of power on its own. 3: I just never got around to removing the hanging block. figure if the winch or battery ever died....... 4: the "white bag" is my main sail in the cover bag and on the boom ;) 5: are you sure the hole in the top of your trunk isn't where it leaks?? 6: my cushions were in such good shape I just kept them. I like the retro look lol 7: Hatch cover is factory fiberglass.
BTW. you're not missing much by not having a manual. it's about as useful as the directions on a shampoo bottle LOL.
Los
Jan 11, 2024
11
If y ou ever make it to socal hit me up for an ocean sail.
Los
Jan 11, 2024
11
Nevermind the above question. I understand it now after studying the diagram more. very clever. I ripped my old bunkboard to make two posts eight feet long. I cut the wood to sit nicely in the side stanchions and drilled holes at the top and threaded an old piece of halyard through them to tie them together and serve as the rear fixed line. I plan to either use your loop system and lift with the boom vang, or if it is faster, I may connect my snap shackle to the top of the A-frame and use the jib halyard to lift it with the mast winch. I can cleat it at the mast if to address tangles and binding. Thank you again for sharing your system. It is very well thought out. Super cool. My adaptation uses what I had laying around.
22
Merit 22 Carter Lake
Hold the loop up in place with the main halyard. I bought a transmission strap from Harbor Freight that work perfectly. Just keep it under the shrouds!!!
Los
Jan 11, 2024
11
Looking for advice on rewiring. The current wiring is a combination of random single wires, household flat 2 lamp wiring, and corroded uncoated copper wiring. It all seems to work but I need more circuits and reliability. These weird wires seem to be jammed in crevices in the space between the inner and outer moldings and I have found only two handholes between the panel on the port bulkhead and the battery. Anyone else done this job? Any advice on removing jammed wires and running new wiring? I am also looking to remove and glass over my through hulls. Any words of advice appreciated. I will post pics as this project develops.
Jul 15, 2022
22
Sadly sold the Merit 22 on May 16th....but bought the Catalina 22 two spots down from mine on the 22nd.
Shakedown yesterday. Maybe the buyer has Buyer's Remorse and wants to trade!!!
Los
Jan 11, 2024
11
This is sad as you have been a great contributor, hopefully you will keep chiming in. I contacted this forum to see if we can get a proper Merit Marine forum started. We will see if that happens.
Jul 15, 2022
22
I'll help whenever I can!!!
RussC
Sep 11, 2015
1,615
That mainsail needs moar roach. WAY moar roach.......(and foot) ;)
perhaps you missed that it's a factory sail for this boat ;). the Merit 22 has a masthead rig and the jib is actually bigger than the main.
RussC
Sep 11, 2015
1,615
After a four year search I'm finally back in the game!! I've continued to sail my Mac25 for the past 10 years but I've regretted selling my Merit22 from the day it went out the driveway 4 years ago, which is about when I started searching for another one to replace it. The Mac is a comfortable camper, but it's loaded down and not really equipped to race. after entering my first sanctioned race two weeks ago I really got motivated to get something a bit more competitive again. as fate would have it, one just happened to come along that I could work a deal for. needs lots of work, as most boats of this vintage do, but the important stuff is there. came with 6 headsails from 100% - a massive mylar 150?, two mains, three spinnakers and one reacher (think assm spinnaker). all sails are in good to excellent condition. also came with a nice 5hp Merc (Tohatsu) 4 stroke motor and an assortment of goodies common to used sailboats. Russ is a hAppy, hAppy boy:). might take a month to get her back in shape to sail after sitting since 2013 but that's ok.
