Centerboard lifting mechanism broke. Thoughts on leaving centerboard down full time?
May 3, 2024
11
Morgan 22 Lake Erie
The boat is a 1969 Morgan 22 with a retractable centerboard. Towards the end of the season, when trying to leave the dock, I ran aground with the centerboard down.
Foolishly, I tried to raise it using the lifting mechanism. It was a soft grounding and the boat was still able to move forward a bit (the direction the CB hinges) so I thought it would go up with some help. Instead the mechanism broke (where the cable connected to the cb) and the lifting cable launched into the bilge through the stuffing box. This caused water to come into the boat at an alarming rate. Luckily we were able to get the boat out of the water and onto the trailer where it sits today.
Now I need to decide on how to go about the repair. The way I see it there are 2 options.
1. The proper way: Reattach the lifting cable, rebuild the stuffing box
Pros- Proper repair, full functionality.
Cons- COST - We would need to move the boat off the trailer and have it lifted onto boat stands so that the entire centerboard trunk is accessible from below.
More difficult repair
2. The "good enough" repair: Glass the hole in the bilge/cb trunk that the lifting cable used to pass through and just let the cb hang. When we need to raise it for trailering we would cleat a line on one side, run it under the boat to a winch on the other side to push & hold the cb into the trunk.
Pros- Inexpensive, simple repair, 1 less hole below the waterline
Cons- More difficult and less reliable way to raise cb
Some context - We leave the boat docked all season, so we only load onto trailer once at the end of the season. If I do repair option 2 I will move to a different marina with deeper slips so that I wont run aground with the cb down again (draft 5ft when down).
I am leaning towards option 2 and wondering if I'm missing a good reason not to. I am not concerned with resale price or insurance. Any thoughts on the situation are appreciated.
Diagram of the mechanism in working order.
At 2700 lbs the Morgan 22 is a fairly light boat. It can be lifted off the trailer safely without a crane or travel lift using 2x6s, cement blocks and a bottle jack or two.
A quick overview of the process.
  1. Lower the trailer tongue jack as low as it can go. This will raise the stern. Block the stern of the boat with the 2x6s and cement blocks.
  2. Raise the trailer tongue jack as high as it can go. This will lower the trailer in the stern and raise the bow. Block the Bow with 2x6s and cement blocks.
  3. Lower the tongue and pull the trailer out.
Reverse the process to put the boat back on the trailer.
Best to sister the 2x6s to make a 4x6.
There are variations on this process, it works and if properly blocked it is safe and allows for the proper repair.
Apr 26, 2015
663
S2 26 Mid On Trailer
That is quite the mechanism to raise the board. I would change it to a design like all other manufacturers use. Catalina, O'Day, etc)
If it's just a centerboard without much weight (not swing keel) you wouldn't even need a winch. Something like an O'Day 23.
I would want it repaired. Especially in Lake Erie. I have limited experience in the Western lake but it seems that keelboats had to be careful to not run aground or hit a rock.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
I had a similar event happened in my Mac with the dilemma of getting the boat off the trailer so that it could be repaired without crane. Jacking the trailer off the ground from bow and stern may appear to be somewhat tedious but can easily be done in an afternoon to allow you to access the actual damage to your hull when you pull the trailer out from under it. If you do a partial repair and break it again you will have to remove the partial repair and any extra damage that partial repair may have caused. It's fiberglass;)
May 3, 2024
11
Morgan 22 Lake Erie
That's an interesting idea. I agree this design is a bit over the top.
I am on the eastern side so 5ft draft really isn't a problem once you are out of the marina. There are nearby marinas with 35ft fixed keels that get around fine.
Glad to hear I'm not the first to do something like this :biggrin:
While I do agree the proper repair would be ideal, I am not following what additional damage I could possibly do by glassing over the hole.
Jun 1, 2004
8,326
Unless your design is a verifiable improvement, fix the centerboard lifting mechanism as was constructed. It is really not a big deal to lift it off the trailer. Besides the method suggested by dlochner, there is the tried and true "park next to a big tree" option. If lifting the boat is the only cost you're trying to avoid, then it's no really an issue. The price of a bottle jack, 4 2x4's and some cinder blocks. $50 maybe?
Besides, your thought of running a line under the boat to snag the keel is unproven, With the keel in the down position it will be difficult to keep the line from sliding up the leading edge of the keel to get the lift started. Drilling a hole or notching the cb might be necessary to avoid that scenario. Which means you'll still need to lift the boat. Good luck with whatever path you choose.
Sep 24, 2018
4,565
Catalina 30 MKIII Chicago
I used to leave my 5' centerboard down all season. A lot of growth would build up on it so I left it down during haul out so the yard could wash it. Only issue was that they wouldn't pull the line up before putting it on the trailer
Sep 15, 2013
708
Catalina 270 Baltimore
I had a 71 Irwin 23 with the same problem. I opted to just leave it down. It worked fine. It was in Florida so I did not have to worry about it hitting a rock. I did have to dive it from time to time and pry it back out. I left it that way for several years until I sold it.
