Thanks! We haven't had a good winter here in ages. Keeping her in the water all winter is nice. But trying to get work done in the cold isn't. lol. I've got a running list of fiberglass projects that will likely have to wait until spring.I have used the terms interchangeably too. And always used zincs even in fresh water. But now I know that Magnesium works best in my waters (and aluminum is OK), that is what I use and try to be specific that they are anodes and not necessarily “zinc”.
Keep working on the boat, as you said, you will get there.
Do you have any boat friends to lean on? Or handy friends who would like to learn about working on boats? That could shorten the refit time substantially.
If you stick with it, you will learn a ton, and know your boat very well.
Prioritize the issues and that can help you figure out what needs to be done before you can start sailing…then work on the less serious stuff as time permits (while you can still get a sail or 2 in each week). If you can’t make it fun, you won’t stick with it.
I am jealous that you can keep the boat in the water all winter. I had to pull Tally Ho out a few weeks ago…and she is winterized and covered for the winter. I did go out this week and remove the prop so I can measure for a new Max Prop feathering prop.
Always something to tinker with on a Good Old Boat
I am pretty handy, just don't know a lot about boats. And I tend to get stuck in a loop of trying to figure out the best way to do things.
"Better is the enemy of good enough". I've been trying to hang out with the sailing club more, life tends to happen.
I set the new years deadline for myself before the car broke down. I had hoped to spend two days a week for the last two months working on the boat. But with the car out of commission that hasn't been possible. I've got her fixed up, just need to get new tires (hopefully) this week. I'm not going to rush the boat, but I feel like keeping my soft deadline is important.
