It would be a lot easier to use 1" plywood, and possibly cheaper. Plywood is a laminate by definition. Why go wild on your own building something that already exists? A layer of epoxy on the outside will keep water out better than varnish. It can be painted if you don't like the wood grain to show. Marine ply should not have voids, which standard plywood will likely have.
