I need to go west marine n buy some wire cause the 10 gauge is too short and won’t make it to the bilge pump, should I get 12, 14, or 16 gauge?
I see, however, that new bilge pump draws 5 amps @ 13.6 V DC. does that change the calculation, Should I still buy 10 AWG?That old black wire spliced to a red wire seems like bad news. Joining red to black invites confusion and accidental short circuits down the road. It also looks like the black might have a chafe mark on it, so discarding it would be good.
Ok, cool, that will be my next move.
A bilge pump is considered critical. A pump’s capacity will be significantly decreased by voltage drop in the circuit. If you mean 10-20 feet one way I’d call it 30 feet round trip. If we assume the manufacturer used 16 gauge close to the pump because the pump draws 10 amps, then looking at the chart tells us a 10 amp critical circuit for 30 feet should be 10 AWG.
Not to overwhelm you @SailingFree44, but I see that the current 2022 wiring diagram for the Marine Raider 800 Gph Automatic Bilge Pump shows a wiring diagram as such:
This drawing is not the best as it does no allow for a manual test with a three way switch.
The old wiring diagram you show in your post #6:
....................... does not show a float switch. I also don't see a float switch in your photos of post #24 unless it's located elsewhere. Maybe a float switch is just "understood" but it won't work without one.
Does your new installation include a float switch ?
That's the way. I would suggest applying GLUED heat shrink tubing as well just over the crimp section. Also wipe a tiny dot of dieletric grease (such as Superlube) over the contact faces so they avoid corrosion over the years.Just crimp it down I’m assuming.
This is NOT an ABYC sanctioned method.I use wing nuts to join 2 stranded wires. Before using them, I turn them upside down and fill with lanocoat and use hair dryer to melt the lanocoat and fill the container all the way down, then let it solidify then put it on the twisted wires. This will keep the moisture out.
Wire nuts aren’t designed for stranded wire. They can cut the strands and impair the connection.I use wing nuts to join 2 stranded wires.
OOOOOOH ! ! ! ! ! That's about as popular as a turd in a punch bowl around hereI use wing nuts to join 2 stranded wires.
