Well tonight was a mixed bag. When I left the house the 3D printer was working on another attempt at the control panel, this time I tipped it up 5 degrees to allow a different printing method and so far it was working. The print lifted again in the exact same spot as before, but this time the area that lifted was just risers and not the part itself. It should be done around noon tomorrow. We will see how this one turns out.
Next up is some bad news... and good too. So the bad. My starter doesn’t engage the flywheel. Good news the starter does turn. I’m guessing the drive gear is rusted to the armature. I didn’t have the tools onboard to remove it, I will have to try again next time I head out here. The good news is I was able to rotate the engine manually. So I know my engine is free. Also as I turned the engine a few degrees, water was also trying to move from my raw water pump so even though I know I need a new impeller, at least the old one is trying. And lastly I installed the new fuel pre filter and water separator. It fit nicely in where the old one was. I just need some 3/16th fuel hose for the fuel return, and a couple feet of 5/16th and my fuel lines will all be new.
And lastly, tonight is my first night sleeping onboard! I decided to camp out on Luna tonight. I just wanted to see how comfortable the cushions are. Well enjoy the pics of the fuel tank and new filter. I know it’s not much, but it’s still progress.
View attachment 205503View attachment 205504
