You can create an account and upload to postimages.com from your phone.Mark
Sent photo to your email, would you forward to forum while I try to learn how
Tnx
Hal
Tnx
Hal
Go to the forum on your phone and start a post in this thread. Click the little image icon just above the text box. Click where it says to “drop an image or click here”. Choose your photo library and you should be able to select the pictures to upload. At least that’s how it works on iPhone. Android is probably pretty similar.Mark and Hayden
I have several photos, problem is I don’t know how to get them out of my photos on my cell phone to send to you guys. Ok call me ignorant
Just brainstormingHe said he has other pics. I can’t see this kind of damage due to rig tension. My guess is the boat was dropped
I'm going with that, too. We may never know.My guess is the boat was dropped
Why would it have to crack on both sides? Once one side cracks a lot of the tension is released.If it was a compression crack from Rigging Tension, why not both sides?
If by “removed and replaced the shrouds” he means removed and reinstalled the same shrouds, then my assumption would be that they counted turnbuckle threads when removing, and restored the same settings when reinstalling. If they actually replaced the wire with new then they best they could’ve done is estimated the tension beforehand and tried to reset to the same when tuning the new shrouds.Gentlemen, crack within half an inch is dead center. I spoke with Chief Rigger @ KKMI in Richmond CA. Back in ‘07 they had boat in to have the six chai plates removed and inspected for rot and re-beaded. He stated that shrouds were removed and replaced without any change being made to tension (?). I’m not an engineer but logic says you have to relieve the tension before you can remove the turnbuckle and shroud.
It is what it is, now to figure how to fix it, take off tension first?
to upload a photo, click on the "attach files" that is below the emoji's and select the jpg file.Mark and Hayden
I seriously think you need a reputable marine professional to look at it and repair it. No offense meant to anybody here but asking people on a sailing forum what to do about damage like that is, in my opinion, a form of Russian Roulette. No one can see the extent of the damage from a couple of photos.I’m not an engineer but logic says you have to relieve the tension before you can remove the turnbuckle and shroud.
Feankly, I think Russian Roulette is more predictable. This has to be looked at at the boat from both inside and outside and a thorough exam needs to be performed. This one cannot be properly diagnosed through photos here.I seriously think you need a reputable marine professional to look at it and repair it. No offense meant to anybody here but asking people on a sailing forum what to do about damage like that is, in my opinion, a form of Russian Roulette. No one can see the extent of the damage from a couple of photos.
