Wow…I thought some of my hacks are bad….… Their quick solution was to cut a hole in the hatch, cover that with a thing fiberglass thingy and pluck some foam out of the bottom of the cushion to hide the botched surgery...
IIRC, the C-30 was the best-selling inboard powered sailboat of all time with well over 6000 hulls made. They did something right. Mr Butler managed to sell north of 15000 C-22s, 6000+ C-27s, plus the bigger boats.Wow…I thought some of my hacks are bad….
I guess I should have said, “no one in their mind would put that bump under the cushion”. But hey, if they plucked some of the foam out of the cushion…that made it all better
Yes indeed; i believe they reached the 20000 mark for the C 22’s.They did something right. Mr Butler managed to sell north of 15000 C-22s,
Having owned and maintained an A4 powered C-30 for 8+ years, I'll mostly disagree. Yes, gas is more flammable than diesel and definitely requires a higher standard of care. 50% or more of the powerboats in my marina are gas and they're not blowing up on a regular basis. The A4 had plenty of power ~25hp vs the 5411's 12hp. It's way smoother and quieter. I now have a 3cyl yanmar and the A4 was smoother than that. Biggest problems with the A4 were they drink the fuel at at least 2-3X the rate of the diesel, the gearing in reverse is different than forward thus they didn't back up without a buttload of throttle, and ethanol gas kills the carbs.I am a much better gasoline engine mechanic than I am diesel mechanic, but I am also a very capable mechanic that knows how a Diesel engine works, so I am able to work on them. I would prolly not have purchased this boat if it had a gas engine in it, simply too dangerous to have in the cabin and not enough torque at low rpm to be useful.
Be really careful with pressure washers. They will wash away the sealant under deck fittings, windows, etc. I had a few leaks after I used one. We've gotten some amazing results using vinegar, baking soda, dish soap and magic erasers spongesThanks for the link… I’m gonna try my 3600 Psi pressure washer and simple green first. The Marina has a small list of approved cleaners and Simple green is on the list and one of my favorites. It did wonders cleaning moss off my MacGregor 25 last year.
oh, I’m going to be resealing EVERYTHING. I doubt the pressure washer is going to make it worse. The pics make the boat look good… trust me here. This boat is a mess… but it’s my mess and I am a happy boat owner!Be really careful with pressure washers. They will wash away the sealant under deck fittings, windows, etc. I had a few leaks after I used one. We've gotten some amazing results using vinegar, baking soda, dish soap and magic erasers sponges
It looks like your port side chainplate might be leaking. Check the integrity of the bulkhead.
“ There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats”Well I took a trip out to see Luna today. She had some water in the bilge that my new bilge pump emptied out in just a few seconds.
I got the throttle cable off the engine and found that the throttle lever works perfectly. I also found some rogue wiring in the engine bay as I removed the batteries so I can turn them in as cores. Found a few more leaks, and removed a few items that will not be needed onboard any more.
I also simply sat down on my settee and just enjoyed hearing the rain tap tap on the hull and felt the boat sway in the waves. It felt wonderful. Time well spent!“ There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats”
