Need to replace the Centerboard up haul line and I can not get the large bolt that holds the Centerboard Bracket in place. This is the one in the cabin next to the mast compression pole. Using a 14" breaker bar and it only moves like 15 degrees and then freezes up as if I were tightening it. Need my entire leg strength to turn it either direction.
Anyone else needed very high torque to get this bolt out?
