Hi again. Can I install a standard, plastic, waterproof inspection port, of sufficient size, into the top of the rotomolded diesel tank aboard my 1984 Hunter 34? Discovered while cruising the Columbia River in November that I have diesel bug or gunk in the fuel after running the engine for many hours. Not fun to loose power with a barge coming at you and no wind to sail out of his way.
I want to get a good look inside the tank and clean it this winter. I will also be installing a dedicated fuel polishing system next month to protect myself against fuel fuel failures.
Have anything else on the forum installed inspection ports into the standard issue fuel tanks from Hunter? How did you do it?
