I don't know what that means but it sounds really deep.As an experienced boat owner my advice to any new boat owner has been "the best that you can hope for, is that you get what you paid for...". In this case, there seems little hope at all...
Sorry about crappy pics best I can do as good phone took a crap. Pics are from a 2011 surveyYou said the aft mast was damaged so that would be the mainmast correct? Any photos of the damage? Inquiring minds want to know!
I am assuming that it is a gaff rigged schooner based on the Rover website. When you say it has all of the sails, what does that work out to? With a schooner there are so many options especially a gaffer.
That looks like a pretty clean break which should be repairable.Crappy pics of the break. I sent a lot better pics to the builder
Talked to the builder again today. Insert sleeve at least 18inch on each end. So 36inch total. Weld in place. Cut the break clean and straight. Insert mast. Re weld into place. Re rig and re line. Add sailsI'm thinking I need to get you to pick a lottery ticket for me.
Great news! (Im hoping the guy's boat is under 100 ft)![]()
I am surprised that they are not having you put screws through the mast and into the sleeve. All really tall masts have a screwed together sleave up the mast because they are too long to ship otherwise. screwed mast spliceTalked to the builder again today. Insert sleeve at least 18inch on each end. So 36inch total. Weld in place. Cut the break clean and straight. Insert mast. Re weld into place. Re rig and re line. Add sails
That is what I intend to do. Saw it in a YouTube video. I intend to do so to both halves.I am surprised that they are not having you put screws through the mast and into the sleeve. All really tall masts have a screwed together sleave up the mast because they are too long to ship otherwise. screwed mast splice
