Hi All,
bought our new to us 2004 210 3 months back..And so i've now started down the old rabbit hole..
so far, here's the winter list..
New engine mounts - shaft was log knocking at certain rpms.. (the price!!!! outch! but ordered the OEM's anyway for ease of install.)
new fuel lines and remove the magic magnet fuel conditioner to simplify the fuel line supply to the engine. (anyone want it?)
pulled the trans while doing the mounts and discovered the splines on the damper plate have about 10% of their teeth left.. so new damper plate on order
pulled the shaft while the engine was up, it is scored from years of spinning - new shaft needed
noticed oil leak from the pump out hose on the oil pan.. need to drop the pan to repair or replace
prop pulled and shipped to a prop shop to get tuned up and a tiny bit of cupping added
ordering a PSS while everything is out for dry bilge
new cutlass to be installed
replace broken bilge pump and float switch - i do not like the way this is setup.. so i will be moving things around in the bilge including the AC pump..
replace all fuel filters
rewire engine pod at helm.. has a ground issue and not getting good values on the meters..
alarm buzzer needs replacing
replaced engine key since the switch was free spinning in full circles
just dropped the dodger off at the canvas shop, it's beyond repair, new dodger now being made
bimini windex peep window to be replaced at canvas shop, bimini is good condition otherwise
while at the canvas shop also dropped off the aft birth cushions.. they stink and are vintage patterned.. and not the good kind of vintage.
ordered folding wheel for the helm
new companion way doors on order.. no more boards, yay....
new battery charger needed.. original with the boat still installed
ipad mount ordered for the helm
house and starter battery... need to figure out how to test their useful life left and replace if necessary with 4 smaller group sized batteries so i can actually move them over the 4D's that are in there now. damn they are heavy and i dont know how i'm going to even remove them.
leak in the forward main hatch.. need to remove hatch completely and reinstall with butyl.
LiFeP04 Battery system to be built and installed.. targeting 400AH over and above the deep cycle led acid bank.
install inverter to run things like the microwave away from the dock 2000 watt sine-wave type
Get a dingy and a torqueedo outboard
My goal is to get the boat to be travel ready by July for a trip down the chesapeake with the family.. and possibly a trip to ocean city MD.. or up north to NYC. our home port is Ocean City NJ.
and thats it for now... i'm sure the list will continue to grow as i pull things apart to clean/repair/replace.
