Cove stripe prep:
For reasons known only to Hunter, the original cove stripe was molded in gelcoat into the original layup. Not a problem until it comes time to refresh it. At some time the PO had that done. The boat yard guys (hereinafter to be known as the "gorillas") solution was to use vinyl tape. Ok, if done properly not a problem. Note I said "if done properly". There seems to be a theme developing here!
Two problems arose from the use of the vinyl tape. One, vinyl has a life-span when exposed to the elements. Removing the cove and accent stripes were right up there as some of the toughest jobs during the hull prep because the vinyl had deteriorated so badly. I'm guessing (hoping) that vinyl has undergone a chemical revolution in the last 20 years so as to last longer and fare better in outdoor applications because what I removed was absolute crap! Two, the design of the toe rail is not conducive to the use of tape in the first place. Since the toe rail lip extends below the hull/deck joint and turns under slightly, it forms a recess that is difficult to access. The vinyl tape in this area was poorly applied and did not adhere well on the upper edge, so as the years progressed all manner of dirt, debris, salt and such got under the tape. Just means more cleanup for me!
Added to that is the way Hunter clamped the toe rail, deck and hull together. The toe rail sits atop the deck edge which sits on top of the hull lip. All three are clamped together via 5/16th bolts spaced 6" apart. I personally like this setup - I think it's one of the strongest joints going. But . . .
What do you do if you need to refresh things underneath the lip?
Option 1: Do nothing. Nobody can see it anyway. Paint the cove stripe and be happy. Um, NO! I think you guys know me better than that by now!
Option 2: Paint the underside of the lip. Um, yeah. But there are 140 5/16ths bolts in the way (not kidding!) and I don't think it's a good idea to just paint over them. Not good for the stainless bolts, not good for the paint long-term.
I can't just remove all the bolts at once, and removing just a few at a time to paint underneath would be a monumental pain, so I settled on removing every other one. After cleaning and prepping, I taped and papered the hull to prevent paint splashes and drips and painted the recess:
Boy, was there paint splashes and drips! I will have blue spots on me for a few weeks until they wear off!
After this dried, I started replacing the bolts (properly torqued, which I bet has never been done!) and removed the other bolts. I was interrupted yesterday by the rain so I only got the starboard side done. After finishing the port side I'll paint the remainder of the lip, then tape off the cove stripe and finish up.
