About 4 years ago I began using TruFuel or similar in much of my equipment. Prior to this I had tried every "stabilizer" known to man, none really did much of anything. The ethanol problem got so bad I was physically replacing the carbs on 2006 or newer equipment yearly. The pathways are even too small for ultrasonic cleaning. My Honda HRX mower had the carb replaced 4 years in a row and this was after "emptying the bowl" and trying everything Honda suggested...
So how does the ethanol free fuel do?
Honda HRX Mower = 100% TruFuel 4 years. Quarter pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all. Prior to TrueFuel nothing but issues each spring.
Stihl Weed Whacker = 100% TruFuel 4 years. Starts first pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all.
Husqvarna Chain Saw = 100% TruFuel 4 years. Starts first pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all.
Stihl Hedge Trimmer = 100% TruFuel 4 years. Starts first pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all.
Honda Snowblower = 100% TruFuel 3 years. Starts first pull each year. I am not draining the bowl. No carb repairs or cleanings at all.
Yamaha 2.5 HP 4 Stroke Outboard = 100% TruFuel 3.5 years. Starts first pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all.
Honda EU2000 Generator = 100% TruFuel 4 years. Starts first pull each year since I began using it and I am not draining the bowl. No carb repairs or cleanings at all.
Yamaha 50CC 2 Stroke Scooter = 100% TruFuel 4 years. HAD NOT EVEN BEEN STARTED IN TWO YEARS! Started last weekend with one kick.
Tohatsu 9.8 Two Stroke = Ran TruFuel through for last 4 hours of run time. Started first pull.
Johnson 40HP Two Stroke (my work skiff) = No TruFuel used Marine Stabil in fall for last two tanks. 9.5 hours of labor in cleaning and re-building carbs this spring. Running like a top when stored for winter carbs looked like a restaurant grease trap this spring...
Generac 5500W Generator = No TruFuel (tank is very large so opted for "stabilizer") would not start today when Microbust killed power.. Carb is a caked gummy mess. Just ordered a new carb.
Amazing differences and surely not a coincidence... My carb issues have 100% stopped on the engines I am using ethanol free fuel in!! But sure, ethanol causes no problems....
Despite the insane cost of this fuel I am MILES ahead in savings..... The Generac will now be 100% TruFuel and my work skiff will run at least 4 hours of TruFuel before being stored.
