MM, thanks for posting the picture. Makes me feel comfortable that my CB is not rotting and de-laminating inside. I did add somewhere between 5 to 10 pounds to the lowest part of my CB - the reason was to get it to drop easier. It makes it harder to pull up. We had a thread on this earlier and cant remember if you already have 2:1 leverage on the CB pull up but that helps a lot of you add some weight.
Also good comment about the water fully draining from the CB when its raised. If you store the boat in a cold climate, trapped water in there would not be a good thing when it started to freeze..
