I tried something yesterday I had been wanting to try for a long time.. I was single handed and it was fairly windy. To set the sails up, normally I will set the main up first - with the motor running and the boat heading into the wind - tiller locked. This works OK especially in lighter winds but yesterday I also would have had to put the reef in the main while setting it up.
Instead, I first unfurled the jib (which was almost all I needed). I then got the boat in "heave to" with just the jib up. I was able to set the main up with the reef and it was a fairly relaxed process. I have discussed this before on forums and apparently it doesn't work on all sailboats (they need some involvement from the main to stay in heave to) but I thought it worked fairly well on the 26S. New trick for solo setup when its higher winds. The motor was not at all needed (it was off and out of the water).
All would have been well after.. except that when I set the main halyard up, I wasn't careful and had it around one of the jib sheets.. DOH! Getting that fixed was definitely NOT RELAXED. Picture below with a reef in both the main and jib.
