I needed a small victory since the sanding and prep in the cockpit continues... endlessly; so I sanded an painted out the the little stash compartments in the cockpit. I used the Interlux BilgeKote enamel for this because priming, sanding, and then rolling and tipping Brightsides would just be ridiculous. To tell you the truth, I really like the enamel and it brushes out fairly well without a primer on sanded and de-waxed gelcoat. I honestly think it would make a good top-coat for the budget minded. At $50 a gallon it is still cheaper than buying 4 quarts of Rustoleum enamel (I think). Anyway, the trim ring is just set in there for the pic, will be glued in with 4200UV after the cockpit is painted out.
