I've used two types of tape. The pink tape that you might see in some pics is Owens Corning painters tape, I got a deal on it @ 2.50 per roll which is amazing for any kind of low adhesive painters tape. When using it I got very little if any edge bleed being careful to firmly press down the edge. For the most part, however, I only used it on the various coats of primers where any 'oops' ended up getting sanded anyway.
I had one roll of expensive 3M 'lime green' painters tape that came from a paint supply store, left over from previous paint jobs on my race bike body work. That's the only roll I had that was exactly .75" vice .91". I used this to cover the sheer stripe primer with one piece when painting the steel grey. Still got some edge tiny edge bleed.
For the final color coats, the steel grey and the white for the stripes, I have been using Scotch Blue with Edge Lock, almost $6 a roll from Home Depot. You can feel a big difference in the tape material and the adhesive over regular blue painters tape. So far I haven't gotten any edge bleed with this at all. You just have to be careful with it and immediately remove it after painting. I had taped off everything one afternoon before the last color coat, then decided to wait until the next day to paint because it was too close to dark and I left the tape in place. If left on too long it will leave an adhesive residue and it also pulled up a few small flakes of the Prime Kote on the boot stripe.
I also think Frog Tape is good, but haven't used it yet because Home Depot was out of stock in the .91" inch size. This too is also expensive, but I think the Scotch Blue w/ Edge Lock is doing just as well and cheaper @ $5.87 vs almost $8.50 for .94" Frog Tape.
CloudDiver,
Are you using fine-line masking tape on your stripes? I'm interested in how well the edges turn out after several coats and days of drying time, whether they peel up when you remove the tape. I'll be doing my stripes soon too.
