Good evening MS...
I removed the 3 loop handrails off cabintop of my precision 23. When I Install new ones in spring, I will through bolt them as recommended, I` going to match the new ones up against the old ones on the bench this winter to locate the boltholes in the new ones. When I reinstall ,I planned to bed them onto some of the butyl I got from you a few years ago. Should I also put a dab of 4200 around on the bolts to seal the hole or is compression of the tape sufficient to d that? , Thanks , Dave, Baltimore.
