Which control cables for 1981 Hunter 33?
Mar 29, 2014
1
Hunter 33 Philadelphia
I have a 1981 Hunter 33 (Cherubini). I need a new set of control cables for the throttle and shifter. Can anyone tell me the correct type and length of cable to purchase, or point me to a resource where I can look it up? Thanks in advance.
Feb 17, 2006
5,274
Most control cables are all the same in design. It is the ends that define what system they work on. On my Yamaha outboard, I can use any cable as long as I reuse the ends that are currently on the existing cable. The length is probably the defining factor. Also, you should think about lubing the cables. There is a youtube video showing how. It could 1) prolong the life of your cables and 2) make shifting easier.
Now, just so you know, no harm in keeping to brand cables. Just giving you an option. You can check here on SBO for control cables.
