A more interesting correlation that he told me about, although I never saw the data or recall whether it made it into his paper, is speed. If you graph the speeds of the vessels up until either finish or abandonment aand convert to speed length ratio, you find that, the faster they went, the greater their chance of finishing.
These were racing boats with large crews used to steering under challenging conditions with a lot of sail up so I don't think it applies to cruising. It may also be a measure of something else like crew ability or getting ahead of the worst conditions.
I believe the winner (Ted Turner) said on coming ashore something like, "Storm? What, there was a storm?".
Ted is a nut
That's exactly what I was told as the safest solution....keeping as much sail up as you can to give you the most possible speed so you can dodge the breaking waves. If you aren't dodging the breaks such as having the autopilot on, I feel you are putting the boat in a great chance of crashing into the trough.
This is not for the average helmsman though as broaching is a real danger and having a breaking wave catch you causing you to slide down the front face of the wave and crash into the trough at 40+ mph is also possible.
The reason you want to use the sails instead of the engine is because the engine's filters have a great chance of clogging. You may have just cleaned your tank a month ago but when you filled it up, you may have taken on bad fuel which has happened to me a few times. Another reason is that the sails stabilize the boat which reduces chance of injury and damage to boat.
I really don't know if I can dodge breaking waves in a hugh storm. I've often thought what type of sail plan would I have. Would I have just the working jib out or part of it? Would I have just half the main out? Would I have a little of both? One thing is for sure, this is when I will love my roller furlings
If you don't have them, you have to make your sail changes before it gets rough.
I see dangers in all solutions. If I have the main out, I had to worry about accidental gybe and bringing down the mast. If I have the jib out, I will have more rolling as it's less stable. If I am by myself, I can't gybe because I have nobody to handle the sheets and/or boom. If I can't gybe, then that may cripple my changes of dodging a breaking wave.
One thing I do know, because I've been studying other peoples experiences and applying my own experience, I have a list of things I can try and I'm sure to find one that will work. I know my list of things to try is much bigger then it was 3 years ago (feathering, heave-to, lying ahull with warps, running and dodging, last is JSD)
I have comfort in knowing that no boat has ever had any damage while on JSD in 15 years of it being around and I have one incase I can't dodge the waves or feel it's unsafe.
