Water in certain storage compartments but not others
Sep 30, 2013
3,626
!! Also check the Anchor locker drain… it’s a real thin tube that comes out below the bow eye on the nose. If that is cracked/damaged this will explain water at the v berth as the water that gets in the anchor locker from rain or anything will drain inside instead of out. Mine had this problem and was easily fixed.
He has a pre-87 boat, no anchor locker.
Likes: SVEclipse
Oct 7, 2025
23
Catalina 22 Chesapeake
How did you fix the leaky Anchor locker drain?
Jun 14, 2024
9
Catalina 22 Memphis
I did a temporary fix using a piece of flexi tube and pushed it down and through the drain hole, I then sealed it top and bottom with a bit of sealant (leaving it clear to drain still). I plan on putting in a proper (larger) drain pipe like Gene.
Likes: RKenSailor
Oct 7, 2025
23
OK. I bought some 1/2 inch through hull fittings like Gene's. Just wasn't sure if there was an easier way. Probably going to go ahead with it this weekend when I finish up my Bow Eye replacement.
Likes: SVEclipse
