He has a pre-87 boat, no anchor locker.!! Also check the Anchor locker drain… it’s a real thin tube that comes out below the bow eye on the nose. If that is cracked/damaged this will explain water at the v berth as the water that gets in the anchor locker from rain or anything will drain inside instead of out. Mine had this problem and was easily fixed.
