Upgrading Raymarine e80--do I have STng or ST? Tips?
Jun 18, 2014
17
Beneteau 40 Herrington South
Hello, I have a 2008 Beneteau 40 with Raymarine 80 chartplotter and instruments. I am planning an upgrade of the chartplotter and looking for advice.
I am trying to figure out if I have SeaTalk or SeaTalk ng?
Is SeaTalk ng comparable with NMEA 2000?
Can I keep my current transducers if I switch to B&G or Garmin?
Does anybody have opinions on the different systems out there? Manufacturers?
Thanks
Tm
Jun 6, 2006
6,983
Hunter 40.5 Harrington Harbor North, MD
SeaTalk (ST)
ST1: circular connectors with 3 wires
ST2: crescent connectors with 3 wires
STng (next gen): circular connectors with backbone network topography. More than 3 wires, superset of NMEA 2000 sentences
SThs (highspeed): waterproof RJ45 connectors (internet cables) superset of NMEA 2000 sentences (uses the same communications protocals as NMEA 2000 with a propriatary mechanical connector. Uses a plug converter to interface with NMEA 2000 items.
SThs is compatable with NMEA 2000 IF you use the special SeaTalk to NMEA 2000 converter (IP addressing to NMEA addressing)
Likes: tmatzzie
Jun 18, 2014
17
Thanks. When my chartplotter boots it says SeaTalk ng on screen but I don't assume it is true to that label. So STng is NMEA 2000 and then I need to figure out the right connectors?
