Below is a picture of my stuffing box for my 1980 Oday 30.
- Always left a small pool of water in the engine room. Now when I touch the rubber portion, water sprays. If I engage the transmission, no leaks, only when I touch the rubber on the attachment. So I’m sure it needs some maintenance, new seals, or something.
- Can I work on the stuffing box while the boat is in the water or will I have a major leak at the dock?
- Where do I start with the maintenance?
- Are there kits I should order for a 1980 Oday 30?
Hello Jim... When you first joined SBO you indicated: "New to the sailing world". Is 2019 when you acquired your Oday 30?
Did you install the PYI Dripless Seal to your shaft log or was it done prior to your acquisition?
@dlochner suggests it is "Probably" over due. If done in 2019 and just occasional use, perhaps replacment of the bellows is not needed. It would be dependent on inspection of the bellows. If they appear to be worn and cracking then definitely look to replacement. If they are sound then biannual inspection maybe warranted. The 6-7 year guidance does come from the manufacturer for the bellows shown in your image.
I would question where is the water coming from? If it is the rubber cracked and leaking then yes replacment is warranted. If it is from the prop end of the bellows then you may need to tighten the bands. If it is the graphite/steel seal then that could be normal and just following the cleaning of the seal may be the solution.
Your question #2. In water solution. This is not advised if you have major corrections to be made. The risk of sinking the boat is greater than most owners are ready to address. If it is just cleaning dirt between the seal (the graphite steel interface) then in the water is ok. Anything else I would be hauling the boat. You might be able to accomplish the repairs in say a couple of hours. In that case a short haul may be the ticket. They haul you and let you hang in the slings till fixed, usually over night. You're the last boat out in the evening and the first to drop back in in the AM.
Continued. #2.
@Ralph Johnstone Provides a great graphic. It looks like your Transmission to Shaft alignment is not to spec. While the PYI Dripless seal is forgiving, a misaligned shaft will prematurely wear the parts on the Dripless Seal, causing them to drip. I would address this with the boat out of the water. I would check the wear on the graphite seal face. It may need to be replaced. Based upon inspection, I would contact PYI with what is observed and get their advice.
#3. You start with maintenance by defining - clarifying the issue. Decide on the path you want to take. Acquire any skills, tools, or parts that are needed. Then schedule the work.
#4. PYI does make a kit. It is not boat based. It is engine, prop shaft size and transmission based. Being this is new to you, I would encourage you hire a competent boat worker or yard to do the work. I would suggest you watch and learn what they do. Then in the future you will be better prepared to do more of the work yourself.
The PSS Shaft Seal is a mechanical seal and is installed as standard equipment by many of the worlds most reputable boat builders and yards. Find out everything you need about the PSS Shaft Seal here.
www.shaftseal.com
Good luck. Sounds like you did a good job recognizing you may have a problem. That is the first step to a solution.
NOTE: These are my opinions and not that of management or moderators....
