I had mentioned before how I got some cheap fiberglass solid rod to use as plugs on vertical surfaces.  I noticed the bumper on the starboard support leg of my boarding ladder hung over the edge of the transom near the waterline.  The simple solution is to raise the mounting holes 3/4".  I over-bored the original holes to 3/8".  I put a piece of blue tape on the inside and used slightly thickened epoxy to glue in 1 inch plugs of the fiberglass rod (which I sanded first, then cut to 1 inch).  After the epoxy cured I used a Japanese Pull-Saw to cut off the excess as close as possible and then sanded flush.  I used this same method when filling the motor mount holes, however the fiberglass rod for those was 5/8 inch.  Same for rudder mounts, using 3/8" rod, but they will be re-drilled in the same place leaving a nicely glass lined hole all the way through.
